Question about DeLonghi DCM485 Coffee Maker
Coffee drips out of spigots, taking a long long time to make an expresso
  • 333 Answers
The seals that are located inside the unit are probably bad or have some debris stuck under them. First unplug your unit before you take it apart. You may have to call the customer service to see if this unit is still manufactured or iff parts are available. If not I am sorry that ther is no quick fix for this problem unles you change the seals.
Posted on Nov 23, 2008
Delonghi BCO330T won't heat or brew on coffee or expresso side. Burner won't heat but power is getting to the machine. 17 months old, out of warranty.
Delonghi BCO330T, this is my third one and it has the same failure. It is a know problem and the answer is they don't care
Apr 06, 2014 | De'Longhi BCO330T Combination Steam...
Where can I buy a good coffee pot machine?
Here are a couple of sites you should take a look at;
http://www.bunnathome.com/products
or take a look at amazon that have everything from drip coffee machines to expresso makers.
http://www.amazon.com/Coffee-Tea-Espresso-Small-Appliances/b?ie=UTF8&node=915194
Feb 25, 2013 | Home
When I just have water in the portafilter it runs through fine. When I put the expresso in it clogs and expresso will not flow through.
No solution here. Utopia directions say to only use MEDIUM (drip) grind. Ain't it awful? I prefer ultra fine grind, frankly muddy coffee.Deb
Jul 10, 2011 | Starbucks Barista Utopia
How do I descale my Delonghi Perfecta? Can't find my manual!!!!
The manual is no longer available at that link. It's better to post an answer than to simply point to a URL...
The answer:
1. Fill the tank with descaling solution (or a vinegar solution, which voids your warranty, but seems to work well...)
2. Power on.
3. Hit the P button (Program). The display changes; instead of the usual icons, you will see the "clean" icon, which looks like rain drops in a circle. (This is for rinsing the coffee drip spigots). Turn the selector wheel to switch to it an icon that looks like a bunch of dots between two vertical bars. This is the "descaling mode."
4. The bottom left button now says "Esc" next to it, and the bottom right is the OK. Hit OK to confirm you want to descale. Then dump the drip pan and put a large container under the WATER spigot (not the coffee drip spigots.) Your descaling solution will come out hot and hard. The machine may pause and re-heat at times, to make sure it's very hot. The solution is hot and acidic - BE CAREFUL! It will go through the entire tank, so use a big container, or be ready to switch it out - or put your machine over the edge of your sink for the job.
5. When the tank is empty, the machine will ask for a refill - this time give it clean water for a rinse. Hit the OK; the entire water tank will be used to rinse.
That's it!
Jun 10, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
Very little water is dripping into the carafe
Try to run vinegar undiluted through the coffee maker first. If this does not help, you may have a plugged valve in the coffee maker or a tube/hole where the coffee maker water should drip through. if this coffee maker has a dispenser(where you put your cup against it and the coffee comes out) then there is likely a plugged up valve. This will require dismantling the coffee maker to clean it. Usually coffee makers get plugged up because coffee leaves a residue that requires scrubbing at time to remove.
May 26, 2010 | Dualit Expresso + Filter Espresso & Coffee...
EXPRESSO MACHINE BRIEL ARTIMIS ES42F
i solved it by taking it all apart, then putting it back together, whoo hey it works
Aug 04, 2009 | Briel Artemis ES42 Espresso Machine
Russell Hobbs filter, cappuccino, expresso, steamer coffee maker
I HAD A GE CAPPUCCINO/EXPRESSO MAKER GIVEN TO ME WITH NO MAUAL OF ANY SORT THE MODEL NUMBER IS 169069. I REALLY WOULD APPRICIATE HELP WITH THIS THANK YOU...
Jul 14, 2008 | Coffee Makers & Espresso Machines
DeLonghi DCM485 Coffee Maker Logo
113 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
