Question about Singer Inspiration 4210 Mechanical Sewing Machine
Will not sew, threads are correct, won't pick up bobbin thread
I have reviewed manual to make sure threaded correctly and was sewing fine before, now will not sew, will not pick up bobbin thread to create stitch.
  • Anonymous Dec 29, 2008
    I'm having this same issue. Someone on another forum suggested running the foot pedal for just a second, then trying to lift the thread again, and that worked like a charm. BUT, even though my bobbin thread is raised, the threads still won't connect to create a stitch.
5 Suggested Answers
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
SOURCE: Thread is not coming up
YOUR PROBLEM IS THE TIMMING IN YOUR MACHINE. THIS HAPPENDS WHEN YOU FORCE YOUR MACHINE TO SEW SOMETHING OR WHEN YOUR NEEDLE BRAKES. nOT SURE HOW TO FIX IT. I HAVE THE SAME PROBLEM. USUALLY A TUNE-UP WOULD DO IT. IT'S ABOUT $99 TO $130.00 TO DO A TUNE UP. i WISH I KNEW HOW TO FIX IT MYSELF.
Posted on Mar 08, 2009
sew dutch
  • 24 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
  • 11 Answers
SOURCE: needle will not sew thread into material
Sounds like the timing is off. Take the bobbin out of the bobbin case and lower the needle into the needle plate. As the needle starts on the upswing, the hook should meet the needle just above the needle eye on most machines. If it isn't meeting at that point then your hook timing will need to be adjusted.
Posted on Mar 17, 2010
  • 1116 Answers
SOURCE: Bobbin thread will not stitch.
Have you had the machine serviced since you purchased it? This is something that should be done at least once a year.
Take the machine to a certified Singer dealer and explain what is happening. There may or may not be something that needs to be adjusted.
Your warranty is still in effect, but is now limited. Attempting to repair it yourself or having someone who is not a Singer dealer repair it will invalidate the remaining warranty.
Posted on Apr 16, 2010
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
Machine saying to rethread the upper thread but not picking up bottom thread from bobbin. Constantly rethreaded upper thread still won't sew.
Consult the owner's manual to make sure it is threaded correctly. Install a brand new needle making sure it is installed properly. Also, be sure to RAISE the presser foot BEFORE threading the upper thread.
If it is still not picking up the bobbin thread, the machine may be out of time.
Jan 20, 2016 | Brother InnovIs QC1000 Electronic Sewing...
I need a repair manual or need to know why when i try to sew it wont pick up the bobbin thread
The easiest thing to try is replace the needle with a brand-new needle. If the needle is bent or damaged, it may not be engaging with the bobbin thread correctly. Also make sure it is installed with the flat side facing the correct direction. Be sure to Raise the presser foot before threading the upper thread so it will seat properly in the tension disks.
Perhaps the following will offer some help:
Needle not picking up bobbin thread Threads Magazine Gatherings Forum...
If there continue to be problems, the timing of the needle and hook could be off.
Dec 20, 2015 | Sewing Machines
I have a new Singer 5532
Put in a new needle. Unthread the machine then rethread it being sure it is threaded correctly--especially through the tension control. Remove the bobbin and make sure it is wound correctly. Replace the bobbin and being certain that it is in the correct position. Check the manual if you are unsure how your machine is threaded or how to replace the needle.
Oct 21, 2014 | Singer INGE 5532 32-titch Heavy Duty...
Brother 1100 threading the bobbin
try changing the needle
rethread the machine top and bobbin
make sure to use every thread guide
make sure the top thread has not come off the thread take up
lever--this can cause the sewing machine to jam
if it's a top loading bobbin--take the bobbin out of the bobbin case
and turn it around and reinsert the bobbin
if it's a side or front loading bobbin take the bobbin and bobbin
case out and make sure the bobbin is inserted correctly into the
bobbin case and that the bobbin case is inserted correctly into the
sewing machine.
Nov 14, 2012 | Sewing Machines
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
When I put the pedal down, the bobbin jams, and cuts the thread
make sure the needle & thread & fabric are correct for each other
make sure ever thread guide is being used
try adjusting the top tension
Apr 01, 2012 | Sewing Machines
Bobbin thread wont pick up
Refer to the manual to be sure the bobbin is feeding the thread in the correct direction.
Mar 25, 2010 | Singer Deluxe 57825 Mechanical Sewing...
Bobbing thread not picking
Make sure you have threaded the bobbin thread correctly. Also your top thread must be correctly threaded in order to pick up the bobbin thread.
Please let me know if I can help any further.
Best wishes,
Graemevm
May 01, 2009 | Janome 6019QC Mechanical Sewing Machine
Singer Inspiration 4210 Mechanical Sewing Machine Logo
53 people viewed this question
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
