Question about Lands Phones
My uniden phone keeps beeping at short intervals. I have no messages waiting, and the beep is louder than the usual.
  • 333 Answers
If this is a wireless phone first I would check the battery this may be a low or battery signal. If you done this then check to see if the intercom or pager button on the main base is stuck. If none of this works then I suggest that you buy a new onen they are cheap enough that it would cost more to repair than to buy another.
Posted on Nov 23, 2008
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Why does it beep every 3 minutes
Hello and welcome to FixYa;
Your Uniden phone is beeping because it alerting you to a message notification.
Charge your cordless; check the message; or this phone will keep beeping. Check and clear all notifications and messages, the phone will stop beeping.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
May 31, 2011 | Uniden Cordless Phone
How to recover saved messages remotely
To retrive the messages remotely please follow the steps...
Dialing In to Your System:-
1.Call your telephone number and wait for the system to answer. (If your answering system is off, it will answer after ten rings and sound a series of beeps instead of your greeting.)
2.During the greeting or beeps, press 0 and immediately enter your security code. If you enter it incorrectly 3 times, the system hangs up and returns to standby.
3.The system announces the current time, the number of messages stored in memory, and a help prompt. It will beep intermittently to let you know it's waiting for your command.
When you hear beeping, enter a 2-digit command from below:-
01Repeat message
02Play message
03Skip message
04Delete message
05Stop playback
06Turn the system on
09Turn the system off
10Hear help prompts
Thanx
Jul 20, 2010 | Uniden DECT 6.0 Cordless Phone ID
Phone beeps before dial tone
usually this means you have voicemail...listen to the messages and delete them and the beeps should go away...
Jul 20, 2010 | Uniden 2.4 GHz Cordless Phone System
I have a uniden dect1580 6.0 and the red light in the left hand corner blinks all the time.
That is the message waiting indicator, it is telling you that your Call Notes (Or whatever your service provider calls it's voicemail) has a message waiting. If you do not have a message waiting, you can turn the light of by following these steps:
When you receive a new voice mail message, the new message LED on the top of the handset flashes and
appears in the handset display. In the event your message waiting light gets out of sync with your phone company’s
voice messaging system, you can manually reset it back to the “No messages waiting” state.
Press and hold FIND on the base for five seconds.
Jan 21, 2010 | Uniden Cordless Phone
How do I record a message on the answering service.
to record something u hold the announce button and wait for the beep then keep on holding it and record your message and when your done let go and youll hear your message.
Jul 08, 2009 | Uniden Cordless Phone EXAI985
"i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
Apr 13, 2009 | Uniden DECT 6.0 Cordless Phone ID
Uniden Dect 6.0, the base keeps beeping
You have your answering machine set up to beep when you get a new message. Go through the menu for setting up the answering machine and turn that feature off.
Apr 12, 2009 | Uniden 5.8GHz Dual Cordless Phone
Voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Sep 20, 2008 | Uniden TRU8865-2 Expandable System...
Voice mail notifier on a Uniden DECT 6.0
press and hold down [find hs] on the base for five seconds
Feb 12, 2008 | Uniden DECT 6.0 Cordless Telephone...
Lands Phones Logo
629 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
