Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Kenmore elite refrigerator water dispensor not working
I just got a kenmore elite french door w/ a bottom freezer refrigerator and the water dispensor is not working at all. Also, the freezer is making ice but they all seem to be normal size cubes even though we have the setting on small cubes. The keypad is not on lock. Not sure why the water dispensor is not working because it worked on my old fridge so i know it cant be the water line. The manual for the fridge does not tell you a thing.
    Scholar:
  • 62 Answers
If you just got this unit, did you purchase it new? Or if it's uner a year old then you should call sera for service under the war. Also, when you first start the unit water has to go through the water tank and it takes 3 - 5 mins before the water starts to work when first hooked up, then should be ok after that. There are several things that can cause the problem. Could have a kinked line in the ref, a bad water valve or even a frozen water tank. Also, did the water ever work since you had it?
Posted on Dec 06, 2008
Icemaker and water spout in door not working
Probable inlet water solenoid valve failure. This solenoid valve is located on the back of the unit and attached to the water supply line from your house.
Jan 26, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Water will not come out of the door dispenser
have you replace water filter ..... an easy test go to back of refrigerator where waterline goes int fridge and revers wires for icemaker and water dispensor and now use water dispensor it should put water into icemaker that will tell u that the switch to dispensor is working and you have a bad watervalve needs replacesed
Feb 03, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water or ice or lights on outside of door
I received my Elite TRIO 795.7101 2 weeks ago. I have ran over 3 gallons of water though it. I am still getting a bad odor and taste when I dispenser water from the door.
Nov 03, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Jun 18, 2009 | Zanussi ZEBF250W Bottom Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
No water and ice cubes
Check the water valves in back of frig. and see if working.. make sure you got a water supply valves may be plugged
Oct 05, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
171 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
