Question about Whirlpool Calypso GVW9959K Top Load Washer
Getting ''FL'' error code w/Whirlpool Calypso
In the middle of my wash cycle, the machine started flashing an "FL" error code. The manual stated that the "overfill switch needs to be reset". I really cannot afford to call in for a service. Does anyone know how to deal with this issue please!!???
  • crymon Nov 25, 2008
    fl error code;unplugged power/pushed cancel now what?
  • sjenirah01 Nov 28, 2008
    I have the same problem, i tried to switch it off and on and even tried manually drained the remaining water, i tried to left it unplugged for an hour, changed the washer position and everything that I could think of.... but all failed, please HELP, i have no money for service repair and to purchased a new washer.....
  • 65 Answers
You can try unplugging the washer and letting it reset the system. thenplug it inand press the spin/drain button. if it still gives you the flood condition chances are the pump is faulty and needs to be replaced. it may be covered under whirlpools warranty for the law suite against the washer. otherwise you can get the pump off ebay for cheep and install it yourself. its just a little messy so if you do it yourself make sure you have a shop vac around to **** up the excesswater.
Posted on Nov 29, 2008
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washer will not work, the flashing light says FL ? Can you help
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What is error code flashing Fl represent? Can you just fill the tub with water from an external source and expect the machine to go into wash cycle by preesing start? Does the tub have to fill throug pump...
Flood Condition:
Jan 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Caypso Washer is flashing FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&!$$
Dec 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Cycle Problem
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso stoped and FL flashes and will not cancel,
Flood Condition:
Feb 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL error on my Whirlpool washer
Flood Condition:
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
I have a whrilpool calypso washer flashing the fl code
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Nov 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
949 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
