Question about Hitachi 43UWX10B 43" Rear Projection Television
I need help
We have a hitachi 53uwx10ba and all the paper work we have on it, said the problem has everything to do with things outside, but it dosent have anything to do with that at all, we were wathing tv one day and the tv in a second change to double vision witch we found out is it called ghosting. We cant figure out how to fix it , we have pulled the tv apart , cleaned it and wiped it down to see if that would fix it but it didnt help ,so i need to find out how to fix this, so if you can help that would be great. thank you felicia,
    Problem Solver:
  • 13 Answers
Take it to a professional, this problem u cannot handle
Posted on Dec 28, 2006
Hitachi 53uwx10ba service mode
are you using an HDMI cable? is it a cheap thin cable or heavy duty?
HDMI cables carry sound but it's possible you don't have it seated completely or it's a cheap cable. or your audio settings on your TV are not set to HDMI if that's the cable you're using. try running your audio setup on the TV Menu.
Dec 03, 2013 | Televison & Video
I have a 53 inch hitachi proj tv...model 53UWX10BA....and am doing some of my own repairs...but one of the 1.8 Ohms resistors keeps burning out. The solders look good...I have tested everything and can...
1.8 ohm are protect on convergence ics --stk-392-110 or stk-392-150---
Change both ics and make sure not shorted pins via solder connections.
Let me know if you need help
Feb 19, 2012 | Hitachi Televison & Video
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 53UWX10BA separated colors.
replace the convergence ICs you can get replacement ICs at the following link with free installation instructions. Use two STK392-150 ICs they are good durable ICs for your model,
Heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UWX10BA convergence problems error code 4
Replace the conv ICs. Sometimes it's just the soldering involved, DK on Hit. But bottom line it's usually the conv ICs. They work very hard in there.
Mr Bob
www.imageperfection.com
510-278-4247
Aug 01, 2008 | Hitachi Televison & Video
Hitachi 53uwx10ba no sound/picture flashing power light cricket sound
Possible shorted cap C702 ? Open E994 pico fuse.....check
carefully with ohmmeter...all fuses and let me know.....T.
Mar 05, 2008 | Televison & Video
53uwx10ba hitachi
only one click?
any blinking lights?
Jan 08, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Green lines along top of Hitachi 53UWX10BA
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi Mo# 53uwx10ba double image
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Dec 03, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
