Question about Dryers
Kenmore dryer won't run
We have a situation where when we press the "on" button of the dryer, it will start, but as soon as we take our finger off the "on" button, it will stop running. Over the last year or so, it would do this but only after extended use (i.e. 4-5 consecutive loads). Now the dryer does this on the initial load and will not run.
  • vernsfishing Nov 24, 2008
    Same proplem stops running when you let off start button. Door switch shuts off when opened with start button depressed.
  • Larry Youngblood
    Larry Youngblood May 11, 2010
    the microcomputer is bad or also know as the even heat control / send me the model number and i will try to help you some more,
    Larry
    Sergeant:
    Champion:
  • 291 Answers
The microcomputer is bad / some calls it a even heat board / send me your complete model number from inside your door panel and i will see if i can help with info on a board / larryyb
Posted on Dec 05, 2008
Dryer won't stay on when let go of start button.
One of two things is wrong. Either the start switch has gone bad or the start winding in the motor is failing to switch over to the run winding. You'll need to get a multimeter and before starting unplug the dryer. Once thats done, get behind it, remove the back cover to the control panal and disconnect the two wires that are connected to the start button. With your meter set for checking continuity, place a meter lead on start button pins where the wires were connected, one lead on each side.With leads in place have someone press the start button, if continuity shows when pressed and stops when its not, the button is good and the motor is bad. Personally, I think the motor winding has burnt, and the motor should be replace, but I also think that the start button should be changed as well because its in direct series with the motor, and could have taken damage that may not show up until further down the road, plus its an inexpensive part.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Kenmore Dryers
I have a Kenmore Dryer Model 11063942101. When I press the start button the dryer starts but stops as soon as I release the start button.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Kenmore 63942 Dryer
When you push the "push to start" button, the
I would say change your Start button should take care of the problem.
FIRST Always unplug the Dryer before doing any work on it.
Good Luck
Dec 26, 2010 | Kenmore 62982 Electric Dryer
When I press start, it beeps, but will not start -- Kenmore HE-3
I pressed the reset button inside the dryer with my finger and then turned the dryer on with the door opened. After I closed it, it worked again.
Jun 16, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer will not run
Hello tomechkojr,
Many dryer motors have a centrifcal switch on the motor that should allow the motor to continue operating after you remove the momentary start switch. Chances are, that motor switch is hanging up and not actuating to keep power on to the motor. Keep me posted and I'll follow along with you to help..
Regards
Rick
Nov 23, 2008 | Kenmore Dryers
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Dryer starts but goes off as soon as I take my finger off the start button
The starting capacitor has low storage of current some are open or shorted , need to replace the starting capacitor.
Dec 22, 2007 | Kenmore 63942 Dryer
psrao, right next to the timer under the consol is the even heat board. When this fails, it will cause this problem. This has been an issue with this model. Part number for the board is 3978949. Catriver..post back.
Jan 14, 2007 | Kenmore 73952 Gas Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
Marvin
Marvin
