Question about Boating
1997 Yamaha Waverunner not starting and no electronics
I have a 97 waverunner that is not doing anything. I have anew battery and still nothing no electronics no starting. It was working two weeks ago, tried to start it and we were able to turn it over once then nothing at all?
  • duwanna66 May 01, 2009
    need codes to reset
Mine did the samething as sooon as i got it on the trailor i tried to start it and the starter was froze up (worked fine in the water) so i replaced the starter and tried it and nothing happend. i went into the black box and figured out my starter relay burned up trying to get power to the starter. works fine now after changing relay and starter
Posted on Jan 25, 2009
We are having the same problem does it click the the electircal box is it the starter
Posted on Aug 31, 2009
  • 21 Answers
Check the kill switch. If it ran recently then you must have a loose wire somewhere.
Posted on Dec 01, 2008
Help with 92 waverunner 650 no spark issue
Hi, Banjomaniac and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or electronic control module or CDI box.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Thread Waverunner No Spark
1991 waverunner III 650 turns over no spark won start Want to fix for the...
Jet ski 91 Yamaha wave runner 650 with no spark need some
http://www.yamaha-motor.com/assets/service/manuals/1998/LIT-18626-03-05_371.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 01, 2016 | Motorcycles
What is the size and year model of my yamaha waverunner the hull id # yama31321394
Yamaha did not make the GP model until 97 and if the numbers you posted are correct you have a 94, that being said all yamahas up until 93 were either a 500 or a 650 so im guessing its not a superjet which is a standup so you may have a waverunner 3, Raider, Blaster, or a wave runner LX. What colors are on it? does it have twin carbs? there will also be a sticker on the engine cases noting engine size.
May 29, 2014 | Yamaha Boating
Yamaha waverunner does not start
hi there it sounds like the switch gear need pulling apart and the copper contacts cleaned as it sounds like the kill switch is closed up and the starter button contacts need cleaning as well also check to see if the stater soliniod might need a cleanup where the wires go,also check your fuses to see if there contacting alright if you ride in all weather or the bike sits outside it can have these problems as mouisture gets into everything. hope this helps cheers pete
Jun 12, 2013 | Yamaha 98 Gp 1200 Air Box Intake Mount...
I have a 2001 yamaha waverunner and the gauges stop working
I have a 2001 waverunner and it stoped runing in the water . Now it will turn over but won't start
Sep 29, 2009 | Boating
How do I reset the code on a yamaha waverunner
How do I reset the code on dash board 99 yamaha waverunner 800?
Aug 02, 2009 | Sport & Outdoor - Others
Waverunner sat for 4 months. thought battery was
Try jumping the waverunner using a set of jumper cables and your vehicle, this will rule out if the battery is bad. If you still have the same issue, check the connections. The connection at the starter or another place may have corroded a bit. Yet another option is to remove your spark plugs to make sure that your motor has not hydraulically locked. Once you have removed the plugs try and turn over the engine. You may need to ground out your plug wires if you have an electronic ignition to protect it. I hope this helps.
Jul 13, 2009 | Sport & Outdoor - Others
Waverunner will not start
Check the fuses under the front in a round cover, 1 fuse is for the starter,but the cover must be on after checking the fuses.
Jun 30, 2009 | Sport & Outdoor - Others
Boating Logo
886 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
