Question about Ovens
GE Wall Oven Temp
A Few days ago I asked advise on an oven temp problem. Are you working on it?
Thank you.
highflyer722@yahoo.com
Dave Harrison
  • 1,543 Answers
Hello Dave;
Are we working on it? Well, honestly, I don't think so. FixYa is a web site where experts from around the world can give advise to individual askers. Most experts log in from time to time and answer a few free questions. Most questions (thousands) go unanswered. Many questions can be answered by searching for similar previously answered questions. Users can use the "ask me" button to request assistance from individual technicians they would like. ie: saw you answered a similar question from someone else, can you help me....... etc. Just about the only way to assure you get a response is to use the pay portion of this web site, as many experts and not quite so experts will jump on any question which might actually earn them a couple dollars. (unfortunately, many of those solutions are poor also, as many of the so called experts who respond are throwing anything out there just to see if they might be lucky enough to pick up a few bucks.)
OK, getting off the soap box now.
The PF (power failure) may be a momentary power interruption. If you are lucky, it could be a loose electrical connection at the household circuit breaker or the wire connections from the household wire to the oven. Loose connection(s) can cause wires to heat up, expand, and cause momentary power interruptions. The PF might also be caused by a similar situation within the electronic range control board, which would require replacement of that part, (WB27K5040) which is unfortunately no longer available.
So,..... in your case, if you don't find any poor electrical connections you will be forced to replace the oven. Sorry.
Please don't bother rating the solution, as anything but a FixYa will lower my score. Carl.
Posted on Nov 23, 2008
Ge true temp oven
Sometimes you will have to pull the oven out to get access to the connector for the sensor. It could be jammed in the back or the hole is just too small to pull the connector through the wall.
Feb 15, 2014 | Ovens
Is there any way to turn off the beeps- starting oven, when it reachs set temp, changing temp
Hello g harrison - Unfortunately the range does not have an adjustable volume level or cannot be turned off. It is designed to advise you of when the oven is starting or reach desire temperature.
Nov 29, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My Mother has a GE oven which is not working properly. The problem: the oven is turned on to bake,it heats up to the desired temp, works for awhile and then the oven just turns itself off and there is an...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Oct 27, 2009 | GE 30" Built-In Single Electric Wall Oven...
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Nov 19, 2008 | GE JGRP17 Gas Single Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
Temp. problems on a GE wall oven
Give me the complete model # from the tag on the oven and I will look into this for you.
Nov 07, 2007 | Ovens
Ovens Logo
150 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
