Question about E-Machines eMachines Desktop PC
Tower sounds like a siren but won't come on.
Even when the tower is unplugged it still makes the siren noise. What could be the problem
    Novelist:
    Scholar:
  • 70 Answers
Strange indeed. Typically the only power left in a system after it is unplugged in older systems is a small battery that keeps the BIOS information. Maybe your system has it set up to warn you through the tiny system speaker that this battery is dead. If it is then the system can't start up...just as you reported.
Any other information would be helpful in diagnosing this problem.
Posted on Nov 23, 2008
MY TOWER KEEPS BEEPING, LIKE IT IS SYNCING BUT DOEST STOP MAKING THE NOISE. WHAT TO DO? I HAVE ALREADY TURNED ON AND OFF AND UNPLUGGED AND REPLUGGED.
Sounds like you might have a hardware issue, computers generally use a loud beep (not from the speakers or headphones) that alert the user that something has gone wrong with it. I recommend you take it in to a computer store to have it looked at. Issues like this might stem from overheating, which would cause your computer to immediately switch off in order to prevent components from further overheating.
Feb 27, 2017 | Tower Computers & Internet
Gateway Computer tower making ringing noise -computer moniter not coming on
See if the Harddrive is making the noise, sscruggs06.
(Computer unplugged from power. Follow Anti-Static Precautions.
I listed them here in a previous solution,
http://www.fixya.com/support/t16277200-check_see_power_supply_working )
Perhaps the Spindle bearings are bad, and Platters are scraping,
http://computer.howstuffworks.com/hard-disk.htm
Post the Model Number in a Comment.
Regards,
joecoolvette
Feb 01, 2013 | Computers & Internet
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspire™ T180 PC Desktop
How to fix my computer PC so noisy
check the noise location.
It could be the internal fan or it could be the CD/DVD drive making noise.
You probably have to open the case/Tower to check what is causing the noise. If it is a fan make sure it is not obstructing with any wire and then close the tower carefully.
It could be the SMPS( switched mode power supply ) the power supply of the computer. SMPS is the box inside the tower where the power cable of the computer gets connected.
Try to check if that is making noise or not .. If it is get that replaced.
If it is a CD/DVD ??
check if the noise comes when the CD is in or it comes even if it is empty.
Both cases the CD/dvd drive needs repair.
Try the steps above and let me know if you have any other question.
May 10, 2010 | Sony VGC-LT32E PC Desktop
When turning my p.c on my screen sais"no input signal" and my tower starts making a bleeping noise please help
Sounds like you have something stopping your tower from booting.
Have your power supply checked out, then if thats not it you may have a bad motherboard or CPU.
Nov 13, 2009 | Acer Aspire 3000 Notebook
My new acer aspire tower has an anoying hum. Is this normal?
Hi Rick,
Ideally there will be some amount of noise emanating from any system, so its normal. The noise factor can be attributed to various components within your tower. Typical components that generate noise are:
CPU Fan - It usually runs at a speed of 1500 rpm
Hard Drive - There are circular metallic discs in the hard drive which run at a speed of about 7200 rpm for normal hard drives
Video Card Fan (if there is one)
SMPS/Power Supply fan
However, if the noise is very audible then you can try the following:
- Ensure that your tower is kept on a flat surface
- There are no obstructions around the power supply fan (found at the back of your tower)
- Power supply provided is proper and coming through a spike buster
If you feel that the noise level is high, then I would recommend contacting Acer support as it may be a problem with one of the fans or the way your motherboard has been fixed within the tower.
Jul 07, 2009 | Acer Aspire™ T180 PC Desktop
Dell tower desktop Dimension 5100. Tower makes whistling sound.
sounds like it could be a bearing in your hard drive. is this problem constant? If so, I would open up the tower and disconnect the hard drive and then power up the tower again. if the sound goes away--you need to get a new hard drive. If not, you could have some dust bunnies in your cooling fan.
Jun 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My tower makes a warning siren when using net or some application
My experience hads been that e-machines do seem to have hard drive noise before going out.
Nov 25, 2008 | E-Machines eMachines Desktop PC
RCA HD52W59 HDTV arcing internal high voltage tower help
http://www.riddledtv.com/repair/RCA.html
http://serviceman.site88.net/index_files/Projection.htm
try these sites see if they help u
need to know chassi
Oct 03, 2008 | RCA HD52W59 HDTV Projection Television
My tower won't turn on. I checked and it is plugeged in to a working outlet... the screen light is on and even one light on the tower is on -- but when I press the on button NOTHING happens.
hi ,
you can try this solution
unplug all cables , powerflee the system by pressing the start button for 30 sec , release it then replugg all the cables and check wheather it is working or not , secondly check wheather the powers supply fan on the back of tower is working or not, still it doesnt work turn off the tower and unplugg the tower and then openthe tower , check all cables and reset the RAM on the mother board ...you can try this basic troubleshooting , it will help u... waiting for response
May 20, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
90 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
