Question about Kenmore Dryers
Dryer will not run
We have a situation where when we push the "on" button of the dryer, it will start, but as soon as we take our finger off the "on button, the dryer shuts off. Over the past year or so, it would do this but only after using it for long periods of time (i.e. 4-5 consecutive loads of clothes). Now, the dryer does this on the initial load and will not run.
  • 706 Answers
Hello tomechkojr,
Many dryer motors have a centrifcal switch on the motor that should allow the motor to continue operating after you remove the momentary start switch. Chances are, that motor switch is hanging up and not actuating to keep power on to the motor. Keep me posted and I'll follow along with you to help..
Regards
Rick
Posted on Nov 24, 2008
When I push the start button the dryer starts but has soon as I take my finger off the button the dryer stops. why is that happening?
sounds like a bad push start button either the switch or the knob is defective, see pics
May 05, 2015 | Dryers
Why does dryer run as soon as main button is pushed.
It can also be a bad relay on the the control board. This problem requires a tech to properly do a diagnostic, its not a simple problem for any technician.
Feb 20, 2015 | Dryers
I have a Candy GOU218 when I push the start button it does start the dryer but as soon as I release my finger from the button it stops, It started doing it around a week ago so I had to push and hold
There are push to start circuits used for motors and then there are holding circuits that keep the unit running. This way the dryer stops if the circuit is open due to high temperature or end of the cycle. It seems as if the holding circuit (could be a rotary switch that stays closed while the dryer is running) or a holding circuit relay (stays closed until circuit is broken by the control) has failed.
Jan 09, 2014 | Candy Dryers
When you push the "push to start" button, the
I would say change your Start button should take care of the problem.
FIRST Always unplug the Dryer before doing any work on it.
Good Luck
Dec 26, 2010 | Kenmore 62982 Electric Dryer
Dryer won't start
I believe you have lost a leg of power.Check you breaker and then the wiring in the back of the dryer.
Jan 09, 2009 | Whirlpool LER5636P Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Kenmore dryer won't run
the microcomputer is bad / some calls it a even heat board / send me your complete model number from inside your door panel and i will see if i can help with info on a board / larryyb
Nov 23, 2008 | Dryers
Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Jan 06, 2008 | Dryers
Dryer starts but goes off as soon as I take my finger off the start button
The starting capacitor has low storage of current some are open or shorted , need to replace the starting capacitor.
Dec 22, 2007 | Kenmore 63942 Dryer
Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
