Question about Apex Digital GB51HD09 51" Rear Projection Television
Red and green wavy lines 3d
In a post you made you said this is caused by a bad convergence circuit, could you please explain how to fix this. thank you.
  • wedson74 Nov 25, 2008
    red and green wavy lines
  • 4,234 Answers
Generally speaking a convergence problem will show up as a picture that appears like a 3D image with a bowing from the top and bottom. If this describes the problem, then try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink that should be marked STKxxx.
Keep me posted.
Dan
P.S.
I am sorry about the late response. With the site changes, the questions aimed directly to me were no longer on the initial page and I was not aware of this.
Posted on Dec 03, 2008
The red convergance lines in advanced convergance mode is wavy and not converging but everything else is.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Hi, I'm having the same type of problem with my tv. It has the 3d look to the screen but it also has a large wavy red line through the top of the screen. Would this also be the result of the convergence...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
69189a5.pngSOLUTION
Jan 28, 2011 | Hitachi 51F500 51" Rear Projection...
My 50 in Phillips rear projection has a bad green tint and switches to a bad red tint what can I do?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Philips Magnavox 9P6034C 60" Rear...
Picture appears curved and colors don't line-up together- looks like you need 3d glasses.
d7382,
Your convergence circuitry is bad. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts at the best price.
Thanks for using FixYa and the generous rating.
hardrocko
Sep 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My tv looks like it is in 3D without 3D glasses,
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The red is offset from all colors.
Sounds like you have bad convergence ICs. If you have gone through the convergence procedure (sometimes called magic focus) and the colors still do not overlapn or converge I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to correct it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 31, 2010 | Panasonic PT-51HX40 51" Rear Projection...
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
  • Screen looks 3D
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Jan 03, 2010 | Hitachi 43F300 43" Rear Projection...
My tv is having a pink and green lines. It looks
  • Screen looks 3D
Dec 27, 2009 | Philips 55PW9363 55" Rear Projection...
Slight convergence problem after changing convergence circuits
My experience has been that the resistors have fallen out of range. These aren't expensive and neither are the caps that surround this area. If you're pulling the board out to change the resistors, might as well change the caps, too. If you're strapped for cash, but have a multi-meter, you can test the caps and the resistors after they've been taken out of circuit to save a little green. Let me know if you need any help testing them; I'd be glad to help.
May 22, 2009 | Toshiba 65H82 65" Rear Projection...
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Apex Digital GB51HD09 51" Rear Projection Television Logo
183 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
