Question about Zoom X6 Adsl Wireless Gateway Rohs Router
DSL Flashing I brought the Zoom X6 so I can have a internet on my laptop wirelessly. Whilst installing the Zoom X6 correctly I realised that the DSL light wasn't solid. I wasn't sure if i needed to replace my Thomas Speedtouch 330 with the Zoom X6. I tried replacing the modems and the DSL light was solid on the Zoom X6 but I have no internet connection on my computer because i needed the Speedtouch to activate my connection and also connecting the laptop to the Zoom network I had no internet connection. Is there any solution to this problem, is there a way to have both speedtouch and zoom x6 connected on my computer??
  • Thomas F. Schneider May 11, 2010
    connect the modem - connect the router to the modem- connect the computer to the router. Problem?
  • 51 Answers
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Posted on Jul 01, 2009
Loss of wireless connection
Is your laptop able to connect to other networks? If so, your router maybe at fault. Reset the router, if it still doesn't work, you may need a new router. If your laptop has issues connecting to other networks, the wifi radio in your laptop may need to be replaced.
Jan 06, 2010 | Zoom X6 (5590) DSL Modem (55900003)
Wireless WPA connection problem to Zoom ADSL X6
ya there is filter oing inbound also check port forwarding in router and check firewall to.
Default ip for access belkin router is http://192.168.15.1
May 05, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Front panel lights
you shoul also have a wireless icon on the x6. if someone is using your wirless link and you are not. the wireless icon should be flashing.
if you don't have the wirelss icon, then you have to have software to monitor the modem activity.
Oct 10, 2008 | Zoom X6 (5590) DSL Modem (55900003)
X6 won't pick up DSL
hopefully you haev installed the software first on yoy computer>
turn off the computer. connect the phone line one end to the ethernet port on your computer and the other end to one of the LAN port on the x6.
power up the (power cube shipped with the X6), the Pwr and the WLAN should come on and become steady, the LINK light should blink,
turn on you computer, connect a new phone line between ADSL port and the wall jack, the LINK light should become steady.
please rate the answer if it solved your porblem.
thank you
Sep 09, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 installation
you need a ethernet network card, if you want it connected to the x6 directly, or you can get a wireless card for the desktop.
the instruction for setup the x6 is straight forward. but you need to follow it to the letter, otherwise it won't work.
if you need more information please email me at frcs68@hotmail.com
please rate if the answer solved your porblem.
thank you
Jun 15, 2008 | Zoom X6 (5590) DSL Modem (55900003)
DSL light flashing constantly
I had the same problem to begin with. Here is what the Zoom helpdesk suggested:
"To force the dsl light to stop blinking, please follow these steps.
1) Open up your web browser and type 10.0.0.2 in the address bar. Type in the the username and password to log in to the modem.
username: admin
password: zoomadsl
2) When you get to the address bar, Click on advance setup.
3) Click on ADSL Configuration.
4) Change the standard to G.Dmt and change the activate line to Start.
5) Save changes and then write settings to flash.
Within a 1 or 2 minutes, the dsl light should go solid."
This worked for me. Good luck.
Mar 24, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 internet light constantly red
the internet light, is usually a blinking green, showing that it's seeing the internet signal. The only reason it's red, is cause there's no net signal..double check the phone line going into the back of your router, and change it if you need to.
check your computers warranty here 4 FREE
Mar 16, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Zoom adsl x6
If the Internet light is off it means you are not either authenticated at your provider or your configurations are wrong on the modem. If you go to your command prompt and type ipconfig and check your IP address and your default gateway. The IP address on your default gateway would be your router put that IP address on your browser and should be able to see your modem setting and any error messages that could help resolve your issue
Feb 18, 2008 | Zoom X6 Adsl Modem/router Rohs...
ADSL X6
presuming that the router moved with you the telephone line socket could be too far away from the BT socket or is not correctly wired. if you have not moved the router then you need to buy a booster
Difficulty in first time support with zoomX6 5590
Hi Maybe i could help you. I have installed this modem before for an ISP provider. Please give me specific task you want to do and I will explain what to do.
Apr 30, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 Adsl Wireless Gateway Rohs Router Logo
196 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
