Question about Linksys Wireless-G WRT54GS Router (e125894)
Swapping Linksys BEFW11S4 for WRT54GS
Have a B router coonected to a server working fine for years. I got a G router, set all addresses, MACs, WEP key, etc the same as B router.
My 3 laptops cannot map drives on the server like the used to on the B router. They do get internet access though.
Server can see the laptops, but not the other way around. Reconnect the B and everything works fine.
G Router is set as a Router and not Gateway.
Severely perplexed on this one.
  • Aris C.
    Aris C. May 11, 2010
    Since you have a server, did you already joined the router's credentials to the domain where the workstation and the server is grouped?
  • Jannette Amandy May 11, 2010
    Can you ping the IP address of the server from the laptop computers?
    Can the laptop computers see each other?
  • 340 Answers
Gateway set to your servers IP address?
Wouldent they(laptops) get internet conection trough the Server? - not sure, just trying to throw a tought in the air.
Coment, and I´ll be back :-)
/Teis
Posted on Dec 08, 2008
  • Teis Thomsen
    Teis Thomsen Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
    /Teis
How do i delete a bt broadband account,??
Here is how to reset your Linksys wireless router to the factory default settings in order to clear any existing properties.
  • Note: All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router user name and password will revert to the default of admin as the user name and no password.
To reset your Linksys BEFW11S4 router to the factory default settings:
  1. Hold the reset button on the back panel of the Linksys router for 30 seconds. All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router password will revert to the default of Admin and all user name information will be removed.
flioqsktle4l2on3s2rwrurpaery4ednch7fnrcft2qykek7dl9puwp12tebm2epxiv1cic0cgjbtccmwjiymzmxbli0zgzkwq5ytgrmzmeowlrkzmtdjf24rlu2laabtaaaaaelftksuqmcc
  1. When you access the router utility to change the router settings from the default values, be sure to leave the User name field blank and enter admin in the Password field.
Aug 18, 2014 | Linksys Wireless-G Broadband Router
Setting up linksys wireless router security wep . Linksys WRT54gs V.5 router. I reset it back to factory defaults. Now I want to make it secure again.
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 07, 2010 | Linksys Wireless-G WRT54GS Router...
I have a linksys befw11s4 router, i dont have a install disk, the router works, i just need to set up and secure my network, how do i do that?
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or "1234" blank.
Then you can see configuration page of router.
If you are not able to access router then RESET it .You can RESET it with reset button it is in back side of router press it for 10 seconds then all settings goes to defaults then you can access it with above link.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 16, 2010 | Linksys BEFW11S4 802.11b Wireless...
My Linksys BEFW11S4 Wireless-B Broadband Router? i cant connect in my internet and my PSP how can i do to connect it?
Set up an open wireless network or with WPA encryption. The PSP supports WEP/WPA but not WPA2 or Wireless G, it's a B device.
Also use a short passphrase and DHCP to lease IP Addresses.
Nov 03, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys BEFW11s4 Wireless Router Security Issues
Try changing the router's channel (play around with 1, 6 and 11) and see if it works.
Jun 28, 2009 | Linksys BEFW11S4 802.11b Wireless...
Lost pasword for linksys wrg54s
User the reset button on the bottom of the router to reset it to factory defaults
Jun 17, 2009 | Linksys Wireless-G WRT54GS Router...
High ping
Question, why are you using so many different routers? Sounds like you are causing a bottleneck in the network.
This is how I have my network.
Modem ---- PFSENSE Firewall (currently my DHCP Server) ------- Cisco Switch ------ Patch Panel ------- out to my Servers, computers and one wireless router. See only one machine is managing my IP addresses.
Buy a patch panel and run wireing to all the locations in the house or just run wireless.
Mar 31, 2009 | Linksys BEFW11S4 802.11b Wireless...
How to setup linksys befw11s4
Use a internal Ip address of 10.10.10.1.
Mar 20, 2009 | Linksys EtherFast Cable/DSL Router
HP laptop not recognizing Linksys Wireless B Security Key..
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Mar 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
WEP
Have you set wep appropriately in both the router and the wireless adapter card? It must be configured in both places.
Dec 11, 2007 | Linksys Bundle: BEFW11S4 802.11b Wireless...
Linksys Wireless-G WRT54GS Router (e125894) Logo
99 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
