Question about Janome Memory Craft 5700
Won't Turn On
Machine shut off while in operation and will not power back on.
  • Jennifer Mattingly Mar 23, 2007
    I found an internal fuse which blew. Odd I would not have expected this to be the result from the manner in which it went.
  • Anonymous Jan 08, 2008
    Sewing a straight stitch on one layer of cottom, machine shut down and i could not get it to power up again. I left it for 6 hours and it finally powered back up. Why did it shut down and then come back on.
    I checked all the outlets and power cords.
    I checked to make sure no threads were caught anywhere in the feed.
  • 944 Answers
In order to figure out this problem, I would need a few more details - in particular what was actually happening just before the shut-down, and if the machine will restart again if left for a while. If you are using a memory card and the machine turns off as it is trying to load software from the card, then I suspect a corrupt memory card or a corrupt file on it. Best way to easily check this is to aquire a second card - ideally if you have a friend who has the same machine that seems to work fine - ask if you can try out their card. (Please make sure that everything is backed up onto a PC or similar in case). If this appears to solve the problem, then reformating your memory card and copying your friends card to yours may be the solution. If this doesn't work then possibly the card itself has failed. If you are not using a card, then the two most likely problems are the internal software or the power supply. Stopping during operation at random, and then turning on again after a while would indicate an overheating problem in the power supply - I have been unable to identify the type of supply myself - if it is an internal supply similar to a PC (with an exit hole in the machine for hot air) then a failed fan is often the problem which should be able to be replaced by any computer shop. If the transformer is of the external type (usually a black box half way along the power cable) then a fan is rarely used - but these transformer units can often fail due to small electronic components or fuses especially if there could have been a power blackout or electrical storm while the unit was plugged in. Usually not worth fixing, these power supply units can be replaced relatively cheaply. Internal software crashes may be able to be repaired easily, but with a specialist machine such as this I would recommend contacting your local dealer - they may not have an expert but should know how to contact one. A first port of call should be; http://www.janome.com/helpdesk.php As they provide a number of software updates and fixes which may solve the problem simply by downloading and installing a small patch correction for the operating software. There are several available for different operating system versions. If you are unsure how to proceed with this, then please find a friend who knows how to download and install software from the internet - it is not an overly complicated operation. If these measures do not seem to help, and if the shutdown occurred when actually sewing/embroidering, then the electric motor itself may have a fault and be overheating. If it turns back on when cooled down, then the motor is hopefully fine, the shutdown was probably caused by a protective cutout designed to save the motor and probably leads back to a power supply problem. In summary: 1. Check if the machine turns on after leaving it for a while, then shuts down again. This almost certainly is a power supply problem, although there could be operating software issues. 2. Check/remember if the machine turned off whilst it was trying to access a memory card, and if possible try with another to see if the problem recurs. 3. Go to the http://www.janome.com/helpdesk.php and check for software fixes/issues armed with all the paperwork that identifies your operating system version. 4. If none of the above solve your problem then I suspect a problem in the motor itself or a motor protection device. This is likely to be best fixed by an authorised dealer as they should have some experience of these problems on your model. 5. If the machine is still under warranty, then please try and get it to a dealer, as any internal investigation may invalidate the warranty. Software updates and fixes, or replacing an external power supply should not affect warranty however, so are worth trying yourself. Hope this helps.
Posted on Feb 17, 2007
SOURCE:
.turn mach. on, it starts running and won't stop until you shut it off
sounds like their is a short some where in the machine and it needs
to be checked.
Apr 03, 2013 | Husqvarna Viking 1
My Pfaff model 1211 machine won't come on. The power switch has been replaced but no light and no power for stitching
Sounds like a bad connection somewhere as the power seems intermittent. Consult your repair man to check the electrics.
Apr 06, 2017 | PfaFF Sewing Machines
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Babylock Esante BLN won't turn on. Wall plug
have you checked the power cord to make sure it's inserted correctly
into the machine?
if it is in the machine correctly, the problem could be the on -off switch
or the power cord
it would be a good idea to have the machine checked at a sewing machine
repair shop
Apr 28, 2012 | Baby Lock Sewing Machines
My Bernina 1230 won't shut off. I need to unplug it each time.
I agree about the on & off switch, it could be going out or have a short in it
Apr 05, 2012 | Bernina Sewing Machines
Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
Mar 29, 2012 | Janome Memory Craft 9000 Computerized...
Comunication error
At first turn the machine off, and then press the start button, reverse button and auto lock button at the same time.
-Turn the machine back on while still pushing the three buttons. After the machine has powered on, release the buttons.
-Press the + sign at the bottom of the screen, continue pressing each + sign as it appears. The machine will display a "Test Complete" message, turn off your machine.
-Wait 5 to 10 seconds before powering your machine back on, your machine will run through a diagnostic test and repair any issues it finds.
If this doesn't work;
Have you set up communication is to the "COM Port" designation within Customizer/Digitizer.
Go to >ScanCard >Communication Settings > choose the COM Port you want to use (find out what COM port the cable's using by going to your Start/task Bar in Windows>Control Panel >System >Hardware >Device Manager >Ports (COM & LPT).
There, you should be able to see what port your cable's using.
Hope this helps
Nov 03, 2011 | Janome Memory Craft 9000 Computerized...
Bernina Activa won't turn on
Lets start at square-one. Have you checked the plug fuse ? Have you checked that the 2-pin mains plug is firmly inserted into the socket on the back of the machine ?
If yes to the above ... are there any lights on at all ... sewing light, display backlight ?
If it's completely dead, it's most likely the power supply 'L'-print which is a separate module screwed into the back of the machine below the spool holders. Your best bet is to get the machine checked-out by a Bernina service agent.
Oct 28, 2011 | Bernina Activa 130
Janome 8000
I took my machine in with the same problem and they told me the display was bad. They told me that they did not make this part anymore. Try and find a parts machine.
Mar 16, 2008 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
181 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
