Question about Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC
DEP error occurs when .AVI files are opened
Data execution prevention error occurs when .AVI files are opened. Please suggest solution for the same.
Thanks and regds,
vasu
    Genius:
  • 1,913 Answers
Go to my computer prerties then advanced u see data executin then add your programs fr wihc u get errors.
Posted on Nov 23, 2008
The application failed to initialize properly (0xc0000005). click on ok to terminate the application
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
You can read more about DEP at:
http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Mar 03, 2011 | Computers & Internet
Tip
How to change Data Execution Prevention (DEP) settings in Windows 7? Data...
How to change<b> Data Execution Prevention (DEP)</b> settings in <b>Windows 7</b>? <br /> <b>Data Execution Prevention (DEP)</b> is a feature that protects our system from viruses and other security threats. The Windows constantly monitors the programs running on our system and closes them if they perform any malicious activity. But sometimes we want a certain program(s) to run even if the<b> Windows alerts</b> us that it is a malicious one. <br /> To change <b>Data Execution Prevention </b>settings in <b>Windows 7</b> follow these simple steps: <br /> 1) Right click on the <b>My Compute</b>r icon on your<b> Desktop </b>and select <b>Properties</b>. <br /> <img src="nonontech_54.jpg" /><br /> <br /> <b>Fig. 1</b> <br /> <br /> 2) The <b>System window</b> opens now. Here click the <b>Advanced system settings</b> link in the left pane as highlighted below: <br /> <img src="nonontech_55.jpg" /><br /> <br /> <b>Fig. 2</b> <br /> 3) The <b>System Properties</b> window opens now. Here click the <b>Settings</b>... button under <b>Performance</b> section under <b>Advanced</b> tab <br /> <img src="nonontech_56.jpg" /><br /> <b><br /></b> <b>Fig. 3</b> <br /> <br /> 4) The <b>Performance Options</b> dialog box opens now. Here select <b>Data Execution Prevention</b> tab and then click on the radio button <b>Turn on DEP for all programs and services except those I select option</b> and click<b> Add </b>button <br /> <img src="nonontech_57.jpg" /><br /> <br /> <b>Fig. 4</b> <br /> <br /> 5) Now select the<b> Executable</b> file (i.e. the .exe file of the program you want to add) that you want to add and click <b>Open</b> button <br /> <img src="nonontech_58.jpg" /><br /> <br /> <b>Fig. 5</b> <br /> <br /> <b><u>Note:</u></b> If you try to add an executable file which cannot be turned off it's <b>DEP</b> feature, then you will receive a warning as shown below. <br /> <img src="nonontech_59.jpg" /><br /> <br /> <br /> <b>Fig. 6</b> <br /> <br /> 6) In the same way, to remove an executable file from the list select that file and click <b>Remove</b> button. <br /> 7) Click<b> Apply</b> and then <b>OK</b> button in the <b>Performance</b> options window <br /> 8) Click <b>OK </b>button in <b>System Properties</b> window <br /> 9) Close <b>System window</b>. <br /> Thanks for reading. <br />
on Jan 28, 2011 | Computers & Internet
I get the following error as soon as i start casino.exe. The application failed to initialize properly (0xc0000005). click ok to terminate the application. please help me. i like konami casino game...
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then would remove them and see if the error goes away. If it does then send the memory back and get a refund!
/NOEXECUTE
This error also seen when people have updated drivers for their graphics card. If this happens just roll back your drivers. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
Mar 03, 2011 | Konami Casino Inc. for Windows
Installing AVG 8.5 on Windows XP professional getting error 0xc0070002. What is the fix?
Your computer's processor blocked an activity of a program by stopping the computer from working to prevent the activity from being executed (also known as DEP or Data Execution Prevention) and giving such error instead.
Try turning off the DEP for all programs by:
- opening Start > Control Panel > System
- Click on 'Advanced' tab
- In the performance area, click 'Settings' button
- A new window will appear
- Click on 'Data Execution Prevention' tab
- Click on the upper radio button (run DEP only for Windows services)
- Restart your computer
If it doesn't work or is turned off for all programs already then there seems to be a problem with your Windows (since you said that IE takes 100% CPU process), or the antivirus program isn't really compatible with your hardware and/or driver software.
thanks and regards
kindly rate this solution
Oct 28, 2009 | Computers & Internet
Internet Explorere keeps closing down
Data Execution Prevention (DEP) is a security feature that helps prevent damage from viruses and other security threats by monitoring your programs to make sure they use system memory safely.
Here is a link to an excellent article on DEP.
Whie it will show you how to turn DEP on, it will also take you to the control panel that will aloow you to adjust your settings.
http://windowshelp.microsoft.com/Windows/en-US/help/1d9bb9b4-f6ba-466d-ac2b-7b8c4f8361611033.mspx
Oct 03, 2009 | Computers & Internet
Why do i keep getting DEP error message each time i close IE8 or a tab?
windows xp has DEP ( data execution prevention ) some viruses etc use that sort of technique and from SP2 onwards I believe it was they included it.
http://www.zensoftware.co.uk/kb/article.aspx?id=10002
Several OSs have no-execute or execute protection. Microsoft has added this as well in SP2 with data execution prevention (DEP). This precents code execution in memory regions already marked as storage. This is a powerful tool against buffer overrun exploits. If a program is failing and you want to disable DEP to see if that is the cause. Here are the steps. (Just disable DEP for the program in question… don’t disable it for your whole system.)
    1. Click Start
    2. Select Control Panel
    3. Select System
    4. Click the Advanced tab
    5. In the Performance region select Settings
    6. Click the Data Execute tab in the dialog box that opens
    7. Select Turn on DEP for all programs and services except for those I select
    8. Click Add.
    9. The open dialog box will open. Browse and select your application.
    10. Click Open
    11. Click Apply
    12. Click Ok
    13. Reboot
May 10, 2009 | Microsoft Internet Explorer 8
  • DEP help's prevent damage from visuse's and other security threat's that attack memory location's on your pc, by default (DEP is turned on for essential window's program's and service's only, it may be possible DEP has been turned on for all program's and service's except those you select, you can check this setting by,
  • going to the control panel,
  • click on system,
  • under the system propertie's box click the advanced tab,
  • in the advanced tab click setting's under performance,
  • from there you will get a performance option's box,
  • at the top to the right there will be a tab that say's Data Execution Prevention, click the tab.
  • from there it should be set to essential window's program's and service's only, this is the default setting.
Apr 16, 2009 | Computers & Internet
Desktop doesn't appear on the computer.
hi there, The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
i would suggest that the ram in your computer has possibly broken down over a period, may i recommend obtaining some new ram, if you go to www.crucial.com they can provide you with information that tells you which ram you have in your PC.
Jan 25, 2009 | Acer Aspire 3680 Laptop
Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
/NOEXECUTE
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Oct 11, 2008 | Sony DCR-DVD608E DVD Camcorder
Intellinav.exe application error
/NOEXECUTE
CAUSE:
Aug 30, 2008 | Nextar Q3 GPS Receiver
Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC Logo
124 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
