Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 43uwx10b after watching tv for about an hour the tv menu screen pops up for no reason. this happens periodically, daily. what can be causing this? we don't use our tv remote, we use our satelite remote so it can't be a problem with the remote. this is driving me crazy!
    Genius:
  • 1,694 Answers
Microprocessor IC glitch?? Try hard reset==leave unplugged from ac (power) overnight.PLug-in,try again.Hope this helps.
Posted on Oct 18, 2007
SOURCE:
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Tip
How to Lose Weight Watching TV
When you want to change your life you probably don't reach for the remote control, but you can do your body a world of good by using your daily commercial-viewing time wisely. Lifehack notes that the average person watches about 3 hours of TV daily, with 15 minutes of commercials during each hour-long block. That means every day you spend 45 minutes staring at a screen while people try to sell you stuff. If you used that time to get off the couch and do something simple—like stepping up and down on a box—you could lose up to 96 pounds in a year!
on Dec 18, 2009 | Health & Beauty
Why does my reciever keep turning off by itself?
try looking into the Timer section on the TV. also on Dish if it is left unattended (like stay on same channel etc) it will go in to sleep mode, U then just hit the Select button.. U can go in the Dish menu and set the Sleep mode (inactivate mode ) to a longer time, I usually set my for 8 hours.
Jul 09, 2014 | DISH Network DVR-625 DTV Receiver /...
Why does menu keeps poping up non-stop when watching tv but when sky box is paused this does not happen, why????
Can you use a digital camera to view your remote to see if it is sending out signals when it should not? It might have dirty buttons from food or other dirt. This can cause it to send signals even when the buttons are not being pressed.
May 11, 2014 | AOC Televison & Video
I have a Toshibal 50HM66 DLP TV. I purchased it about 4 yrs ago. It worked well for 4 months and the bulb popped, since then I've had to replace the bulb 3 times at a about $150 per bulb. The last bulb...
I have had the same problem and after several trips to the shop I realised it was caused by humidity. The shop was air conditioned so the problem never happens there. A dehumidifier or air conditioner "solved" the problem.
Dec 27, 2009 | Toshiba 50HM66 52" Television
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
RCA 52" Menu Keeps Popping Up and Down
I see this alot at the shop ... the front panel buttons have become damaged. THe best coarse of action is to replace the front button cuircit board assembly... **** there is a tempery fix untill you get the part... remove the front panel and take button cuicit board out...just use remote to control the tv. This is also a way to test to see if this is the problem.. if you romove the connector to the buttons and the problem goes away then the buttons are the problem. you get get this cuicit board at union electronics. You have to get the extended model number off the back ussally d52w20yx1 or yx2 or yxsomething...not to difficult a repair
Nov 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 51F510
Same problem but mine goes black for long periods. Menu prompts still available and volume "meter" on screen is still visible. Have rerouted cable, changed outlets, all to no avail.
Mar 28, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
103 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
