Question about Addtron Workgroup Networking Hub
Problems with Addtron AES820TX Hub
I have an issue with an Addtron AES820TX Hub. The device is passing traffic, but I am unable to ping the IP address that has been assigned to it. This occurred out of the blue about 10 days ago. Tried rebooting it, and still it will not respond to ICMP, yet continues to pass traffic. Any thoughts other than perhaps the device is just faulty?
  • 3 Answers
Is there any change in the configuration made, like is ICMP blocked. If youa re bale to pass traffic without any issues and if the issue is just that you are not able to ping the HUB there is a posibility of blocking the ICMP requests.
Posted on Apr 29, 2007
I am unable to connect to my server
Do you has a static IP address for the firewall that connection to your route.
PING IT with your phone.
Do a traceroute from your ph,
Allowing Pop3 traffic to pass though the firewall?
Jan 13, 2014 | Samsung Galaxy S III S3 16GB Verizon
Tip
How to Troubleshooting Network
Here you will learn network troubleshooting tips, fix tcp/ip errors, tcp/ip settings, internet connectivity errors, how to fix pc errors, lan connectivity issues, traceroute and ping commands. Whether your operating system is Windows or Linux network problems are likely to arise. Many times the network problems arisee due to improperly configured TCP/IP settings. Following is the basic checklist to identify and troubleshoot the basic networking errors.
1. First of all you should learn what stopped working server or client computer also see if the outage affecting the other computers or only one.
2. If you server stopped working you should inform the users of the server and you should start working on fixing the error.
3. If a single client computer stopped working or disconnected from the network, ask the user of that computer that what recent changes cause the server to stop working such as newly installed software or games, service packs, internet software, new hardware or any other thing.
4. Check the physical network connectivity. The most network problems arise due to the physical layers failure.
5. Check all the network cable connections. You can start at the NIC and check if the green light is blinking then check the hub and see if the computer is getting the link across the cable.
6. Get a cable tester to check the connectivity of the cables.
7. Finally start pinging the network both Windows and Linux have the PING command. You can use ping command in this way start > Run > cmd > type "ping" then IP address of the other computer
on Mar 25, 2010 | Computers & Internet
For some reason I am unable to get onto facebook however anyother websites are fine....like my computer is blocking facebook?
ping the face book site
that is go to the DOS prompt and type ping www.face book.com this will give give 4 replies back if the site is responding. If not then you have a firewall issue or a DNS (Domain Name service) issue.
Ping this ip 66.220.153.15 if you get the site with this then there is a problem with the DNS.
Apr 29, 2010 | Computers & Internet
Hi when i connect my ir 3300 with computer the ir3300 is showing network problem. even i had change two no. of cross cables.
Wich kind of problems, you are unable to ping the copier or you cant print, or ...
If you connecting the PC directly use the croswired cable if you are connected over HUB, or other network device you must use normal UTP patch cable, from copier to the HUB, and from the HUB to PC.
Do you have right IP, subnet and gateway?
Check the network cards on copier and PC, if you crimp the cables by yourself check the cables,...
Do you have printer FLASH on your copier?
When did errors occured? Were you able to print before?
Dec 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
I had an idea to use a working addtron 16 port hub as a cheap and simple way to allow our boys access to the net and have control of their time online as well :>) We have a verizon account with an...
You do what you are describing, attach the hub to the router in any regular lan port. Then just plug everything you need to into the hub. Make sure dhcp is on on the router (it probably is) and just set it to automatically obtain the IP on the computers attached. The router can go through the hub (or switch) to give them IPs.
Aug 12, 2009 | Addtron (ADH-0016) Networking Hub
Addtron AEF-1004 network hub faulty?
Hey Beastman,
You have a real beast screwing around in that hub. You have choises:
1. Call the animal control department :)
2. Shoot it with a 22 :):)
3. Get another one.
A Hub acting like that has got its marbles juggled. Switching it on and off is the only way of flashing, and if that doesn't work, its jinxed. If you network it, you could spend a lot of time fixing network problems.
Hubs are cheap and not worth the headache.
Good luck.
Feb 21, 2008 | Addtron (AEF-1004) Networking Hub
Networking issues
Hi gymny,
The best connectivity in hosting application is using virtual ip network. Normally DHCP always changing IP in everytime your computer reboot or shutdown.
Hope this will be helpful to your problem.
Best regards,
Philip
Oct 17, 2007 | Cisco (WS-X3011) Router
Problem with SXP2224WM compex switch.
If I remember correctly, this device has vlan. Did you check to make sure that the vlan is configured or turned off? And does this have a firewall? Seems like a firewall is blocking ping port but allowing traffic. Also, I thought the 24WM was a 24 port switch, you mentioned a hub, but what kind of hub is it? It really sounds like a port blocking issue.
Jun 17, 2007 | Compex (sxp2224wm) Networking Switch
Netgear FR114P with Netgear DS108 not working
DNeser, Port forwarding and static routes isn?t the route to go down to fix this issue. I have an FR114 in a similar configuration and yours should work as well. -When connecting a hub to a router you should be using a certified, standard Ethernet cable, not a crossover. Make sure it?s certified for at least 100 Mbps. -If you are using port 8 on the hub to connect to the router make sure the Normal/Uplink button is set to Normal. -Are the Link and 100 Mbps LED green on both the hub and router ports you use to connect? If not try a known good cable; if that doesn?t work try different ports. Let us know how things work out and please don?t forget to rate this post.
Feb 24, 2007 | NetGear FR114P Router
Addtron Workgroup Networking Hub Logo
125 people viewed this question
Top Addtron Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Addtron Computer and Internet Expert? Answer questions, earn points and help others
