Question about LG WM2688HWM TROMM SteamWasher
LG WM2688HNM washer lights come on and chimes but will not start
All lights come on...can hear chimes...can select type of load... can change hot/cold settings etc. but when push the start button - nothing. Get no errors of any kind. Have unplugged it for 15 min. and plugged back in...no change. Have unplugged overnight and plugged back in...no change. Washer is a little over 1 year old and has worked perfectly up until two days ago. Any suggestions would be appreciated. Thanks
  • askperri Nov 30, 2008
    I have the same problem. The waher will stay on as long as my finger stays on the button.
  • netdex24 Dec 10, 2008
    Yes mine as well I've had mine for about a year also an it just started this about a day ago I've turned it off left it alone...but still it turns on like it wants to start but, then turns right back off! HELP PLEASE
SOURCE: LG WM2688H Front Load Washer
te means the thermistor is not in circuit,( contacts could be dirty disconnect plug and reconnect )should work on cold water or if it is washer dryer combo the thermistor on the dryer could be faulty
Posted on Sep 13, 2007
  • 100 Answers
SOURCE: LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Posted on Dec 05, 2007
SOURCE: LG WFT1081TP Top load washer
I WANT KATALOGE WASHING MACHIN MODEL ; WF-T1081TP BECOUSE MY KATALOGE MISSE
Posted on Jul 13, 2008
  • 98 Answers
SOURCE: Spots on clothes after washing
Put another filter on before the washer. Try to find out if it is in the hot water or the cold. If it is the cold try a filter. If it is the hot, replace your hot water tank.
Posted on Jun 06, 2009
SOURCE: LG Tromm WD 12270 RD washer and dryer
Hi, I don't know how to fix your problem, Lia, unfortunately, BUT wanted to say "Thank You!!" for mentioning that you can get the washer to run through the cycle by rotating the drum and switching to cold water wash! We'd tried unplugging, leaving it unplugged overnight even, but the code/beeping started immediately after plugging back in. I'm kind of longing for an old-school washer right now, thinking of all the things that can go wrong with the newer digital-age computerized ones :-) If you see this, please share what you did to solve your washer problem! Hoping it's not too expensive to fix...or I should say to GET it fixed :-\
Posted on Jun 08, 2010
Is it possible to modify the water temps that are preset to the types of cycles? Casual is warm/cold and Heavy Duty is hot/cold. I would like to do cold/cold but it won't let me
You could connect cold to both hot and cold washer connections by using a hose wye fitting . If the hot and cold supply faucets both open together you will have to cap the hot faucet. Hope this helps.
Dec 12, 2013 | Maytag EPIC MFW9700S Front Load Washer
Lg tromm wm2688hnm schematics
yes it sounds like you have somthing in the pump this video will help
Jul 22, 2013 | Washing Machines
NO WATER INTAKE WHILE RINSE OPTION IS ON
It sound like the cold water inlet valve is faulty, the rinse cycle uses only cold water, and the water in the 'wash' cycle is probably hot.You need a new inlet valve, which on your machine is probably a double hot/cold unit.If you can't get a new inlet valve, a handyman/electrician may be able to change the wiring to use the 'hot' inlet valve for cold water which will allow the machine to wash, and rinse, using cold water through the hot valve..Tikka?...Good luck...Nomess
Jun 01, 2010 | LG WFT1071TP Top Load Washer
LG front load washer. Clothes are warm/hot at end
got me on that 1 , i'd call the nearest appliance shop explain to them whats going on and see what they say
Jun 16, 2009 | Washing Machines
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
Mar 09, 2009 | LG WM2487H Front Load Washer
Hot water goes into cold water washes
Jan 12, 2009 | LG WM-1832C Front Load Washer
Water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Aug 26, 2008 | Maytag Washing Machines
Washing Machines Logo
60 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
