Question about Roper REX4634KQ Electric Dryer
Roper (REX5634PQO) dryer will not start
A scissor fell into the lint trap. My daughter started the dryer and started making crazy noises. I removed the rear panel and retrieved the scissor from the lint blower area. Now the dryer will not start. I checked and reset the circuit breaker. What can it be?
  • Shana Jeffrey-Stone
    Shana Jeffrey-Stone Nov 24, 2008
    I have the same model of dryer. It was working fine last night, and now all of a sudden it will not start when I push the button.
  • Roper Master
  • 8,220 Answers
This fuse mounts right beside the filter housing. Maybe you unpluge a wire while fiddling with the housing. If this fuse blows then the dryer will not run.Roper (REX5634PQO) dryer will not start - 8ab116a.jpg
Posted on Dec 16, 2008
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 | Dryers
How do I remove a sock that fell through the lint trap?
How To Fix Dryer Lint Trap Problems (Removing Items That ...
? 5:32
Feb 4, 2015 - Uploaded by UKaToNeN
Have you ever had something fall down into the lint trap on your dryer? It`s happened to more folks than you ...
how do I get sock out of lint filter shoot of electric dryer ... > Manage My Life > Questions
I'm sorry to hear that a sock fell into your lint screen chute and I would like to assist you. Be sure to unplug the dryer prior to servicing it! Do not run the dryer until you are able to remove the sock! There are two ways to do this.
Nov 29, 2015 | Electrolux Dryers
it may have worked its way into the b,lower. u have to remove cabinet and then remove blower cover and try to find it.
Aug 27, 2014 | Kenmore 500 6952 Dryer
A pencil fell into the lint trap of my the dryer is making a grinding noise. Not sure how to remove it.
Take the lint trap out and turn on the dryer and it should force the pencil out through the outside vent by the blowing action of the air.
Apr 01, 2011 | Dryers
I pulled out the lint trap to clean it and it was overloaded with lint. Most of the lint fell back and when I turned on the dryer, it blew out but it started making a very loud rattling noise and smelled...
If you are feeling resistance trying to re-insert the lint screen most likely the duct has clogged further down (a load of my husband's shop rags packed mine solid one day). Needless to say it's not safe to run it like this due to the risk of fire.
You can try using a dryer lint trap brush to dislodge the clog. But with it being clogged to this extent probably the best way to make sure it's cleaned out properly is to remove the duct inside the dryer. This would involve taking the back off the dryer and some dissasembly, so if you're not comfortable with doing that please call a professional.
If you feel comfortable with doing this, FIRST make SURE the breaker to your dryer is off and the dryer is unplugged.
1. Turn the dryer around and remove the vent hose from the bottom.
2. Remove the screws to take the back panel of the dryer off.
With the back panel off, you will see the duct on the left hand side that leads from your lint filter on the top of the dryer to the blower housing at the bottom.
3. Remove your lint filter from the top, while doing so note that there are 2 screws right next to it on the top, remove these 2 screws being careful not to loose them in the duct. These hold the top of the duct to the dryer.
4. Next follow the duct down to where it mounts at the bottom to the blower housing, you will need to remove these screws also. there also may be a couple midway up that will be securing the duct in the dryer.
The duct should then be able to be removed from the dryer. Clean it out throughly, be careful, the edges are very sharp in places. Re-install, being careful not to drop the 2 top screws back down into the duct while replacing (you may want to install the lint filter first).
This video shows the procedure of the duct (or airbox) being removed and cleaned with the exception of the removal of the top 2 screws by the lint screen.
Feb 13, 2011 | Roper REX4634KQ Electric Dryer
Sock fell down lint vent and daughter turned on dryer
Turn off you power to the dryer and then,
You could run a coat hanger straightened out with a hook bent on the end of it into the lint vent at try to hook the sock.
But probably you will have to remove the back to follow the lint vent.
You may try to remove the vent hose and run the straightened coat hanger in there to try and remove the sock.
Hope this helps
Sep 30, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Bottle cap fell into lint trap behind the drum,
take the top cover off the unit(after UNPLUGGING unit of course)screw location varies on units,some you need to remove front cover first to access screws for top
Aug 05, 2009 | Amana DLE330RAW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
135 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
