Question about Hitachi 53UDX10B 53" Rear Projection Television
53UDX10BA - Broken Mirror
The Mirror inside the back cover of my Hitachi is broken. The above part number is for the TV...Is this part number the correct one for the mirror? Can I just go to a custom mirror shop and have one made? Here is the replacement part number. HRM-KS-0202-8
  • Anonymous Nov 25, 2008
    Is it OK to have the mirror made at the local mirror shop?
  • 333 Answers
As far as the part number I could not tell you. But you need to get this part from the manufacturer. It should be installed by a service teck because when replaced the tv projection system needs to realigned. I hope this helps you.
Posted on Nov 23, 2008
  • Frank Russo Nov 23, 2008
    Please do not remove the back of this unit until it unplugged. remember safety first.
Remove tv screen from hitachi projection tv
The entire screen unit can be removed but first remove rear cover and look at the lens--clean with a lens cloth etc----peek up inside and look at the mirror--if not dirty or smudged just clean the lens.
removing the screen with its frame can be tricky--easy to damage the screens etc. Removal usually requires front speaker grill to be removed first---most just pull off but a few are secured from rear by some screws.
With it off look to see if at bottom of screen there are a row of screws--if the entire front unit can be removed it will pull out at bottom and be snapped in place.
A better suggestion is look at rear of set above back cover--if the upper part is plastic--it with the back removed can also be removed--careful as mirror is bolted into it---that way you can clean the mirror and get at the lens for the tubes without trying to remove screen unit--some of the smaller sets this is the ONLY way to get at the mirror.
Yes a number of screws but if plastic upper rear comes out with mirror much easier and safer way.
May 29, 2012 | Televison & Video
The mirror inside the TV has broken. Where can I get a replacement?
Go online to Hitachi and browse for a dealer in your area that sells/fits spare parts.
Dec 21, 2010 | Hitachi 50UX26B/27K 50" Rear Projection...
Mirror broken how do i get a new one
Could be.. try to email hitachi service .. or even call the manufactuer.. depends if you can afford to buy a new tv or not.. or willing to replace glass.. its probably cheaper to replce mirror.. you could get exact dimensions from manufactuer and try to get it custom made or buy it somewhere or tile cut it or something.
Dec 16, 2009 | Hitachi 43FDX01B TV
My 53UDX10BA is HDTV-ready. Where can I get the
Your TV accepts HD inputs from HD cable boxes, video game systems, Bluray players etc. There is no adaptor needed just connect the HD device to the component inputs on the back of the TV which are GREEN/BLUE/RED in color. Please take a moment to rate my answer. Thanks..
Nov 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I dropped my flat screen TV. When I turn it on, the screen is broken inside.The outside looks fine...
There is a reflective mirror in that, you probably damage that mirror when you drop it.
Oct 27, 2009 | Hitachi 65F59 65" HDTV
How do I get my TV open to clean color lights I have a Hitachi 42in projection tv
You can take the back cardboard cover off to get to the lenses on the picture tubes. Usually, if the picture is dull because it needs cleaning, the mirror should be cleaned. You can remove the top half of the back of the tv and the mirror will be mounted to the inside of it.
Jul 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi Rear Projection mirror
Call around to tv repair shops maybe one of them has one and yes you can have a new one cut at mirror shop friend of mine broke one while in for repair cost was 150.00
Nov 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Broken mirror
Call 18006383328 tritronics or 18002744666 andrews and have model number. It is just a mirror and you can measure yourself dimensions or just iorder new one.
Craig www.classtorations.com
Jun 07, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Free TV
It probably has a broken mirror or somethings inside the set blocking part of the pic. Now for ther picture all red. If your not a tech I highly advise you going insidew this . Unless you know about the saftey issues and the HI voltage issues. Your problem could be a shorted Picture tube all the way to na bad distribution block . Good Luck
Jun 30, 2006 | Hitachi 43GX01B 43" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
187 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
