Question about Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A
Freezxer dosn't work
I bought a used GE refrigerator/freezer for our daughter a couple years ago for her to use for her appartment. As it turned out her appartment came with appliances. I've had it stored in the garage and thought that maybe we can use it as an extra refrigerator for the holidays. I turned it on and the refrigerator works fine but the freezer won't freeze a cup of water. Now I wonder if the freezer ever worked. The freezer gets cold but not freezing cold. The Refrigerator/Freezer is a GE 22.5 Cu Ft Model 23z - No Frost with automatic Ice Maker. Are there things that I can systematically check out. I am electrically and machanically inclined. Thanks for your help.
  • 306 Answers
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Posted on Nov 23, 2008
What is weight of kenmore freezer model 25320402002?
For 5-foot-tall units: A 32 refrigerator or freezer weighs about 150 pounds and takes up 38 cubic feet. A 32-inch refrigerator or freezer weighs about 200 pounds and takes up 44 cubic feet.
Jul 05, 2018 | Kenmore Freezers
How do I turn the Demo mode off of my GE Upright freezer so my food will freeze
Lisa, you may have to contact the store where you bought it or contact GE. I looked all through the manual a couple time and nothing found on Demo mode. Check the attached links to contact GE for info., last link is USA. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Home GE Appliances
Contact Information
http://products.geappliances.com/appliance/gea-literature-search?Ntt=FUF20DURWW&x=10&y=9
Apr 12, 2016 | General Electric Upright Freezer...
I bought a bush fridge freezer 2 years ago and it just stopped working i then had to buy another one is there anything i can do
buy a better make next time . lots of places sell service agreements or maintanance agreements like Sears and fix or replace the items free for the lenght of contract
May 11, 2015 | Bush Freezers
STANDING WATER UNDER DELI TRAY
Try going further than defrost and draining the hose. There is gunk that builds up and you need to clean that out. Use a pipe cleaner(the fuzzy wires used mostly for art projects. They actually can clean pipes and water lines!!) Also, you can pick up a pack of pellets used for breaking down the "gunk" build up.
Mar 06, 2014 | GE Profile : PFSF6PKXWW 25.5 cu.ft. Bottom...
We bought the Commercial Freezer T-23F last month and the unit never works right, we had a service persons came in to fix it two time, both time they fix the defrost timer and it still the same. The...
Is it factory new, never been used? Or are you saying you bought a used one and they replaced it with a "new" used one? I am familiar with True Manufacturing and if it is a new unit you have a one year parts and labor warranty. The dealer you bought it from is the responsible party to fix your problem.
Aug 29, 2010 | True 23 cu. ft. / 651 liter Commercial...
Freezer bought in 1996. Moved to new address 3
what brand refrigerator is it? model number?
Mar 22, 2010 | Freezers
I bought a used Kenmore upright freezer, it's been running all the time.
The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
Jun 02, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
GE S/S Refrigerator model GSS20IEBWW auger not turning
Take a hair dryer and heat the auger drive gear. These will sometimes get moisture on them and freeze up.
Turn the refrigerator off first. Then remove the ice bin. The "U" shaped drive will be in the back.
After you have heated it thoroughly, try to move the gear manually. Resume power and try it again.
May 19, 2009 | GE Freezers
My brand new freezer wont freeze
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
Apr 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A Logo
289 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
