Question about Hitachi 53SDX89B 53" Rear Projection Television
Periodic blackouts i been getting these blackouts lately, i get them more when i watch Hi-Def movies from my satellite on directv with my HD tivo, it happens also on my ps3.
  • 1 more comment
  • shane tinkham Jan 01, 2007
    any one???
  • Anonymous Dec 15, 2007
    My 53SDX89B also periodically blacks out when I watch HD shows. Loud sounds, explosions etc. seem to set it off more often, but it can also go out without them. I have an HD cable box from Comcast. The cable system has been checked and the box replaced, but it still does it. Very annoying.
  • jagiu Jul 29, 2008
    I have the same problem but it also happens with progressive DVD player. Called a repair guy hopefully he can fix I'll let you know what happens.
3 Suggested Answers
SOURCE: Hi-Def?
Yes, it is HD TV ready but you must have a set top box from your cable or dish company that provides a Hi Def signal. The inputs must also be connected with the YRB cable. Only certain channels on my box are HD. The screen is so large that HD isn't nearly as impressive as some of the smaller models but it is still HD. I also have the 53FDX10B.
Posted on Apr 01, 2009
hardrocko
  • 1476 Answers
SOURCE: i have a 50" hitachi rear projection tv, do i need
rozmyers,
You do not need a high def receiver, your unit has an ATSC tuner which is the same thing. You do need to hook it up to a high definition signal. You mentioned that you have satellite. Call your supplier and order the high definition channels if you do not already have them on the downlink. They should be able to tell you if you have them or not. They should also be able to tell you which channels they are (normally the higher ones). Once you have a high definition feed you will have the best picture you are going to get with todays technology.
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Posted on Jan 09, 2011
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
Hooking up hdmi cable from laptop to tv
yes it will. when u plug in the HDMI. right click on your desktop and adjust your graphic properties for your secondary screen
Jan 03, 2009 | Tivo Series2 TCD649080 Video Recorder
Hooking up laptop to hdtv with hdmi cable
Only if your graphics card can handle HD viewing
I'm getting cable channels but no high def
Your TiVo is only recording basic cable (i.e., channels it can receive without a cable box). You will need a digital cable box from your cable company to record channels above 99. If your TiVo is a Series 2 you will not be able to actually record in HD either. You should be able to record the HD channels from the cable box, but they will not be HD quality. (This is my current setup and while the picture quality is much better than basic cable, it pales compared to bypassing the TiVo and watching HD directly off the cable box to the TV.)
Dec 23, 2008 | Tivo Series2 TCD649080 Video Recorder
Need to program a directv philips series 2 remote
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
Dec 20, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Directv DVR vs Tivo
I found the manual for that model online, and according to it, the "Live TV" button should function exactly the same way your old Tivo did.
If it's not working correctly, you may want to contact the manufacturer, assuming it's still under warranty.
Aug 06, 2008 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
Non-HDMI Tivo connection
The solution I use is S-Video from cable box to TIVO, and from TIVO to TV. That gets you the highest quality signal that the TIVO can handle. To watch true HD signal, switch TV from S-Video input to Hi-Def input and tune to HD channel. I have an HD cable box connected to both outputs, your situation may be different.
Feel free to ask for more help.
Jeepster77
Jan 16, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
Hitachi 53SDX89B 53" Rear Projection Television Logo
61 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
