Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 error code 34
I got a Mitsubishi WD-52525 for free because the owner couldn't find out what was wrong with it. It was saying it had a bad lamp, so I replaced it. It still has no picture and no sound, but I can hear the fan running. I held in the devise and menu buttons and got error code 34. I read some of the answers on this site and saw that you had said to replace the capacitors. Is this a common fix for this tv and problem? Does the kit show you where the PWB is or is it best to get the service manual also?
Thank you for your time and advise.
  • 18 Answers
Replaced 2 capacitors 3300u/35v. At the power board.
do not tuch the rest of the chassis...............
Posted on Aug 23, 2009
I replace the bulb and I'm getting a blinking error code 3 4. How do I fix? Mitsubishi WD-52525
That code can often be caused by failed capacitors on the power board which will cause the 34 error for lamp abnormality. The V26 Power repair kit at www.tvrepairworld.com may fix that issue. The kit contains the replacement capacitors and has the CD with instructions.
Dec 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Error code 34
Thats a problem caused by the failed capacitors on the power board. Heres a link to the repair kit which fixes that issue usually. The repair kit contains the capacitors and the CD with detailed instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Nov 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinks wd 52525
Thats a 34 code which means lamp abnormality. This is related to the bad capacitors on the PWB PCB just helped a guy last week repair his. You need the repair kit thats called V26 DLP PWB PCB Kit its 35.99 at the following link and contains all the capacitors and a CD that shows how to disassemble the chassis and identify the PCB and which capaitors go where. Heres the link and they also give free tech support to help you with the repair.
Jun 30, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replaced the Lamp and get nothing, SOund works, no picture
Replace both 3300uf capacitors on the PWB thats a common cause with that model when it displays a 34 code which is lamp abnormality. if you need more information and I can psot a link where you can get the kit to repair your set with full instructions.
Jun 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
May 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed ctechnicians.com and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 New lamp-Code 34-Lamp abnormality?
check that you did not bend you connections on the lamp housing
when you reinstalled have seem this happen
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
449 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
