Question about Tomtom GO 300 GPS Receiver
No maps when i turn one my tomtom one,the screen says "no maps found", and it will not do anything else can you help me ?? brian
  • 1,031 Answers
You probably have a directory on your Storage Card called \Storage Card\My Documents\Map_Name
copy the Map_Name folder to the root of your Storage Card
so you have \Storage Card\Map_Name
restart TomTom and it should pick up the map back. if this didnt work then probably the card directory where the map is stored may corrupt or unreadable try reinstalling the map
at least this has worked in many tomtom one’s
And one xl’s that i have tried,
First of all connect your tomtom to your computer.
making sure your online,Go to log on.
if you’ve not created an account create one now.
If you’ve had to create an account restart tomtom home.
You should have the tomtom home screen in front of you,
Now even if tomtom home is showing you logged in, ignore
this click your email adderss in the top right hand side of the screen
and log in again and click continue.
Then click Device/disconnect device.
Now your tomtom will update itself and your maps will be restored
please let me Know if this has worked for you.hope this helps pls apprecite by rating as fixyaa thanks and Godbless
Posted on Nov 23, 2008
I have a new TomTom Go 2535 that is reading No Maps Found! I have tried a hard reset with no luck. The TomTom seems frozen. Can you help me...
Usually, you'll want to connect a new TomTom GPS to your computer, and (using TomTom HOME), register the device and get the latest maps (downloaded and) installed on your GPS.
Then, you'll have maps on your GPS.
Aug 31, 2012 | Tomtom Go 2535 TM WTE GPS Receiver
Screen reads"no maps found"
I found this article online, and it may work for you:
"Ok this has worked on at least four tomtom one’s
Now your tomtom will update itself and your maps will be restored"
Jan 11, 2008 | Tomtom One Europe v2 GPS Receiver
No maps found on a tomtom one xl
how do i fix my tomtom 310 will not turn on it is charged but will not turn on?????????????? how do i fix it
Dec 19, 2009 | Tomtom ONE XL GPS
Turn on tomtom and it freeses screen with no maps found.
try doing a reset,hold button in for about 15 seconds,then try again if it still doesnt work try a hard reset,go to tomtom.com for instruction on hard reset
May 11, 2009 | Tomtom GO GPS Receiver
Tomtom one displays no maps found
The problem with that approach is that you cannot transfer maps from another device onto yours without product key activation codes. This is to prevent piracy or abuse of maps on individual devices.
Did you find a good solution?
May 22, 2008 | Tomtom ONE GPS Receiver
No maps found
I had the same problem how ever after downloading all the software updates and pretty well evey thing that was available on the tomtom home sight suddenly the map was there. It could be a soft ware bug.
Mar 19, 2008 | Tomtom One XL GPS Receiver
No maps found??
my tom tom 510 would start, i have charge the tomtom with green light on, but tomtom is not coming up
Feb 09, 2008 | Tomtom GO 510 GPS Receiver
Tomtom one
Hi Steve de may.
Try removing your SD card and inserting again. If the problem persists then I recommend you use your backed up copy to restore the SD card. You did make a back up on your PC, right?
The other possibility is that in the preferences section of you tom tom the wrong map has been selected or a map that it cannot read has been loaded. Remember newly purchased maps must be activated first before use.
I made a copy of may original SD card and use that in my tomtom. If anything goes wrong, I can always restore it from the original. I also made a copy on my PC using the Tomtom "Home" application.
Hope this helps.
Regards,
Spare head 2.
Jan 03, 2008 | Tomtom ONE GPS Receiver
No maps found??
The problem is caused by a version mismatch between the Application version and the Map Version. They must both be the same. For example, if the TomTom has not had the application updated, but you updated the maps, the TomTom will not know how to read the file.
Make sure that if you are trying to use a version 815 map, that you are using a version 8.XXX application too. I had to upload two application version changes before I could read the new USA maps.
Dec 25, 2007 | Tomtom ONE GPS Receiver
Tomtom GO 300 GPS Receiver Logo
163 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
