Question about Seagate (ST380011A) 80 GB IDE Hard Drive
Seagate SATA Baracuda 160 GB harddrive crashed
I bought a new Seagate hard drive (SATA) and loaded Windows XP on that along with 3d max , etc, software applications.
Just after 24 hours, when I restarted the system, the OS crashed and even I lost the partitions also, means all my uploaded applications were also lost.
Before Seagate, I used Hitachi, which also had given same kind of problem and even developed bad sectors after every hard disk failure.
Can anybody suggest me how can I stop this crashhing and what are all the measures I need to take?
  • 38 Answers
I've found this to just be the nature of hard drives. You never really can trust them, thats why you always need a backup. Maybe look into a fault tollerant RAID solution if it's really important (kinda expensive)
Posted on Jan 13, 2009
My desktop crashed. I lost everything on it. I thought I downloaded some informatin on my Seagate Externa harddrive, however, I am having problems connecting to other computers to see if any information is...
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
Aug 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Baracuda 7200.7 in a RAID0 array has failed. On Drive diagnostics Drive test get error message "Drive Failed! Return Code 7". What is the drive error?
Hello mmincalgary:
This drive error code 7 means the controller board that controls the drive has failed, the board is located on the harddrive itself, Replacing this drive will solve your problem, unfortunely Segate has had many issues with this drive especially the SATA ver .7, 160GB versions..
Sep 26, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
320 GB Seagate SATA Harddrive appearing as...
Try changing the harddisk setting in the bios at startup. Check the settings are set to SATA.
Dec 18, 2008 | Fujitsu MHV2160BT 160 GB SATA Hard Drive
Maximum size of hard disk supported
Hi Bijay.
Neither is at fault. Please click on this Seagate link:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=How_To_Install_and_Troubleshoot_ATA_Hard_Drives&vgnextoid=559e5b1142aec010VgnVCM100000dd04090aRCRD
Scroll down to: Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
Follow the instruction on the web site.
This Seagate web site will help you setup the Seagate 160 drive.
If you feel the drive is still at fault you can run Seagate’s SeaTools. Click on the next link:
http://www.seagate.com/www/en-us/support/downloads/seatools
This software will check the 160GB drive.
(Follow the online instructions for), SeaTools for DOS.
In a Windows XP system & using a FAT 32 & a cluster size of 16kb instead of NTFS. Windows will see the total size of the drive but can only access 149GB of drive space. 11GB of drive space will be used by the FAT. File Allocation Table. The FAT is windows guide to every cluster on the drive.
XP uses NTFS & sets each cluster to 4kb. This 4kb size lowers the total usable GB size & uses more GB's for the FAT. You're 127GB size may be correct for a Win XP system using a NTFS file system. The FAT is using 33GB of drive space as a locator for every cluster on the 160GB drive.
Help with understanding the NTFS file system: http://www.microsoft.com/windowsxp/using/setup/expert/russel_october01.mspx
Bijay if you are still having trouble understanding please post any questions here.
Mike
Aug 12, 2008 | Intel D845GLLY Motherboard
Seagate 160 gb capacity problem
the harddrive size is in another measurement system and the actual size of the drive is exactly what you are seeing 152.
here you can see how my disks show
894a905.jpg 160GB disk - 152,66GB
1000GB disk - 931.51GB
that is correct.
Jun 15, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Boot difficulties Seagat Baracuda 7200, 300 GB
Could have something to do with the IDE being set to master.. It has been known that sometimes the SATA drive will take over as the master.. Try changing the IDE drive to cable select, and see if that helps.. If not, change the SATA to slave.
If that doesn't work, post your motherboard model# along with your bios name/version.. and we'll go from there.
As a side note: When they are connected the way they are now, does the bios show both drives?
Mar 28, 2008 | Seagate Barracuda 7200.8 300 GB Hard Drive
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
123 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
