Televison & Video Logo
Anonymous Posted on Nov 23, 2008
PANASONIC DVD RECORDER
Hello from Australia. I've just recorded some programs from Television to the PanasonicDVD Ram disc. Two hour standard play. I've used the long play and extended play option so I can extended it's length. I'm utilizing the DMR-ES30V machine as it's plugged in to record from the television.I've also just purchased the DMR-EX88, can this machine play the information I've recorded on the RAM disc, which was from the DMR ES30V. It's going from one Panasonic machine to the other. If so what's the process.Let me know. sabojams
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
  • Posted on Nov 23, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3090103
Points
19604
Appreciate the direct "Ask Me".
Since both are record capable:
  • hook the Video and Left/Right Audio OUT of the DMR-ES30V to one of the composite/matching INPUT of the DMR-EX88;
  • use the DMR-ES30V as a player and the DMR-EX88;
  • to be able to watch and monitor the output, temporarily hook up the OUTPUT of the DMR-EX88 to the INPUT of the TV.
  • Anonymous Nov 23, 2008
    and of course the blank disc to be used in the DMR-EX88 is not a rewriatable but a standard DVD Recordable that could be finalized.
    With your indulgence I have to ask, in your original problem here, may I confirm that you awarded the FixYa (correct solution) to Slick54.
3answers
I am trying to record with a sony dvd-r disc and the recorder don't recognize it. the only disc that works is the dvd ram 4.7 but that disc does not work on other standard dvd players. what is the answer?
According to the official description of that recorder, you should have no problem, this is from the description for the DMRES15:
Recordable DVD Media
Record your favorite shows onto DVD-RW, DVD-R, DVD+RW, and DVD-RAM DVD discs. The DMR-ES15 is also compatible with DVD+R Double layer media and provides up to 14 hours of media recording.
Multi-Format Player
Don't worry about limited playback capabilities, the DMR-ES15 can play DVD, DVD-RW (VR Mode), DVD-RW (Video Mode), DVD-R, DVD+R, DVD+RW, DVD-RAM, VCD and CD-DA discs. Also, you can play your favorite songs from CDs or MP3 files, and JPEG images.
4answers
PANASONIC DVD RAM DISC RECORDING
Hi and welcome to FixYa,
To my knowledge the only basic requirement to play a recorded disc into another machine (even of the same brand) is that the disc must be finalized. The recorder must be instructed that no further recording is intended and that the recorded disc wold be in use externally (some other standalone player).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Playback of recorded programs
try formatting the disc. it will erase everything on the disc and you can start fresh. try this with all the discs.if the problem keeps happening, try new discs.
wg
Won't format and or won't read disc
I have a similar problem in that it will not record at all or not record very well.  It has a drive inside like a PC DVD drive called the DVD RAM drive. The horrible clunking (grinding) sound is the disc slipping in the spindle. Unfortunately here in Australia the fix is to replace the whole drive (AU$350)!!
I have opened it up and tried to adjust the force of the spindle and it works for a while.
Hope somebody has a better solution.
I can't play DVD-RAM recored on my camdorder on my computer
dvd player on computer must handle dvd-ram standard
Dvd-ram 4.7gb
DVD RAM discs don't need finalised, hence its not an available option.
They will play directly on other players -*** BUT*** ONLY DVD
RAM players.
Don't expect your RAM disc to play on a normal
DVD+/-RW DVD +/-R device. Its not going to happen unless the
device supports DVD RAM also. If it does, it will play your RAM
disc once you've finished recording in your own DVD RAM
recording unit. Pop it out of your unit, straight into the other, and
the jobs done.
2answers
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Can I playback my movies on a DVD-ROM drive?
No, DVD-RAM disc recorded on the DVD Camcorder will not play back on every drive. Some of the new DVD-ROM drives designed to be compliant with the new DVD-RAM book2 standards will playback discs recorded on the DVD Camcorder. Many previous DVD-ROM drives on the market that came out before the DVD-RAM standard was released will not play back discs recorded on the DVD Camcorder. HITACHI manufactures DVD-ROM drives for some PC manufactures as OEM products. HITACHI model GD-7500 DVD-ROM has DVD-RAM read/write compatibility.
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
