Question about RCA P46812BL 46" Rear Projection Television
RCA 46" Rear Projection TV - Picture is Blurry and RED
I have an older RCA Rear Projection TV. It has a Wood case and the PICTURE is really bad. I have adjusted the colors on the back of the TV to show the best. And it looks fine. But after I turn it off. Then if looses the setting's. Then I have to adjust it again. Please any information would be wonderful. I have taken off the back of the TV. I can see where there are 6 adjusting on the right side. When I turn them the picture does get better. But I do not want to have to do this each time I turn it on. I just want to get he picture where it will not need to be adjusted each time i turn on the TV. PLEASE HELP. Sam SPMoore@nc.rr.com
    Problem Solver:
  • 5 Answers
That sounds like the screen and focus controls you are adjusting. It sounds like you have a bad HV Splitter inside the TV. #205064 or #204809 Depending on your model number. http://www.matelectronics.com/acatalog/Mat_Electronics_Replacement_Parts___TV_134.html sells them for about 20 bucks.
Posted on Jan 21, 2007
Hitachi 46F500 TV has red and blurry picture.. what to do?
If this problem has been gradually getting worse, it is most likely to your picture tubes getting weak, and it is time to replace the set I'm afraid.
If the red is smearing off to the side of reddish objects in the picture it is most definately the tubes.
Nov 02, 2009 | Hitachi 46F500 46" Rear Projection...
Is the tubes going out on my rear projection tv?
If the red, green, and blue colors are separated like a rainbow, then the convergence amps are going out. This set has a common problem of two electrolytic caps going bad. The caps are in the upper left-hand corner of the main board and will have a bulged top if bad.
I would not think the picture tubes are bad, especially all at once.
- Dan
Apr 28, 2009 | RCA D52W19 52" Rear Projection Television
RCA projection tv is blue and fuzzy
may be convegence try turning down the blue screen and see that that does see if the picture clears...
Feb 04, 2009 | RCA Televison & Video
Rca projection tv is blurry
Find a large rifle and put it out of its misery. Bowing is either from a problem in the pincushion correction circuit or the convergence circuit. Blurry picture or poor color rendition is most likely bad CRTs ( picture tubes)
michtech
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
Blurry picture
you can try to clean the mirror and lenses. or try to adjust the focus for each CRT(picture tube). also could be a convergence alignment issue. check the main menu for convergence alignment feature.
Apr 07, 2008 | RCA P46924 46" Rear Projection Television
RCA P46921. Just changed flyback.
First, this assumes nothing else is going on to cause it. Here's what I did. Go to the 'green grid' via the v76 menu and go through the alignment there. Notice that there are red letters, blue letters, and a green grid. While you are in this screen, adjust the red, green, and blue focus watching the individual color's item until they are in focus. If they won't focus here, they won't focus and you have something else wrong (what I do not know). Then, return to normal programming, then select menu on the remote, then screen, then adjust projection tv convergence both horizontal and vertical crosshare. That ought to get it.
Mar 16, 2008 | RCA P46921 46" Rear Projection Television
Rca projection
Conversion problem most likely. Do your conversion controls work both colors in all 4 directions.
Jan 04, 2008 | RCA P52926 52" Rear Projection Television
Hitachi really red picture
Wally, 2 things can cause that, 1) bad solder on red driver transistor (mounted on Red picture tube board) 2) bad red cathode in the red tube which means big bucks (new tube), may not even be available on that old of a set. Hope this helps BMW Rider
Dec 12, 2007 | Hitachi 46UX24B/25K 46" Rear Projection...
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
221 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
