Question about Microsoft Xbox 360 Console
Xbox controller for windows
Internet connection not working when I plug in the Controller to my computer >> so I have to unplug it then restart the computer .. in order to get back the DSL connection.
  • 47 Answers
Visit the link :http://www.xbox.com/en-AU/support/xbox360/live/connect/connecttolive-intro.htm
and this will give you what you want.
Let me know did it solve your problemXRFP28
Posted on Nov 24, 2008
Walmart controller not working on my pc
Set up a wired controller
Step 1: Install the Xbox 360 controller for Windows software
Use the installation CD that came with your Xbox 360 controller for Windows before you connect the controller for Windows to your computer:
  1. Insert the installation disc in the CD or DVD drive of your computer. If the Setup program does not automatically start, change to your CD or DVD drive and run the setup program.
  2. On the setup screen, click Install.
  3. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
If you don't have an installation disc for your Xbox 360 controller for Windows, you can download and install the software online:
  1. Go to the Software Downloads section of the Microsoft Hardware website.
  2. Select Gaming as the product type.
  3. Select Xbox 360 Controller for Windows as the product.
  4. Select the version of Microsoft Windows you are using on your computer, select your operating system language, and then click Download.
  5. Click Run.
  6. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
Step 2: Connect the controller to your computer
After you install the software, plug your Xbox 360 wired controller's USB connector into a USB 2.0 port on your computer.
Step 3: Test the controller
To test your Xbox 360 wired controller on your computer, follow these steps:
  1. On your computer, click Start, type Run, type joy.cpl, and then press ENTER.
  2. Select Xbox 360 Controller, and then click Properties.
  3. Test your Xbox 360 wired controller by pressing a button, pulling a trigger, or moving a stick on the controller. If the controller is functioning correctly, you will see the corresponding action light up in the application. If the application does not recognize your controller, see Troubleshoot your Xbox 360 controller for Windows.
Jan 06, 2014 | Microsoft Xbox 360 Controller
X box controller keeps turning itself off - I have put new batteries in
Connection problems might be caused by one or more of the following factors:
  • Weak batteries or a weak Xbox 360 Rechargeable Battery Pack
  • Interference from another wireless device, such as a microwave oven, a cordless phone, or a wireless router
  • Metallic objects positioned between the console and the wireless controller, such as a chrome faceplate or metal dividers, shelves, or doors on an entertainment center cabinet
    Note All licensed Xbox 360 console faceplates are tested for interference, and do not interfere with licensed wireless devices.
  • There are already four controllers connected to the console.
uparrow.gifBack to the top THINGS TO TRY Solution 1: Restart your console Turn your console off, wait a minute, and then... Solution 1: Restart your consoleTurn your console off, wait a minute, and then turn it on again.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 2: Replace the batteries or the Rechargeable Battery PackInsert fresh AA batteries, or attach a fully charged Xbox 360 Rechargeable Battery Pack to your controller. If you have an Xbox 360 Rechargeable Battery Pack
  • Remove the battery pack and reattach it to your controller, making sure that it is attached correctly.
  • Press and hold the Xbox Guide button. In the upper-left area of the Xbox Guide button, the battery meter indicates your current level of battery strength. You might need to recharge the battery pack, if the level is low.
If you have an Xbox 360 Play & Charge kit
  • Make sure that the Xbox 360 Rechargeable Battery Pack is correctly connected to your controller and plugged into one of your console's USB ports. If you check both of those things but are still having the problem, try the suggestion below.
  • Plug the charge cable into each USB port on your console, one by one. There are two USB ports on the front of the console and one on the back. If the controller works in one USB port but not another, try another accessory in the USB port that did not work with the controller. If the USB port does not work with any accessory, your Xbox 360 console might need to be repaired.
  • Turn off vibration feedback (rumbling) on the controller. If you play games with feedback while charging, it takes longer for the controller to charge and might drain the battery pack faster than it can recharge. Here's how to turn vibration off.
    1. Press the Xbox Guide button on the controller.
    2. Go to the Settings area, and then select Preferences.
    3. Select Vibration.
    4. Select Enable Vibration to clear the checkbox.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 3: Remove objects between the controller and the consoleThe controller works within 33 feet (10 meters) of your console. However, objects placed between the controller and the console might reduce this range. In addition, objects that use wireless technology (for example, a cordless phone) can interfere with your wireless controller. Remove or relocate objects or wireless devices that might interfere with the wireless controller or console. Here are some things that can cause problems:
  • Microwave ovens
  • Cordless phones
  • Wireless routers
  • Chrome faceplates
  • Metal dividers
  • Shelves
  • Doors on an entertainment center cabinet
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 4: Disconnect all controllers and headsetsIf all four rings surrounding the power button on the console are green but the controller has four flashing green lights, four controllers might already be connected to the console. Disconnect all of the controllers, and then try to connect the controller with the problem.
  • To disconnect a wireless controller, press and hold the Xbox Guide button for three seconds, and then turn the controller off.
  • To disconnect a wireless headset, turn the headset off.
  • To disconnect a wired controller or headset, unplug its cable from the console.
To learn more about connecting your wireless controller, please read the following Knowledge Base article: 906947 (http://support.microsoft.com/kb/906947/ ) How to connect an Xbox 360 Wireless Controller to an Xbox 360 console or computer If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 5: Replace your controllerIf your controller still does not work correctly, it might need to be replaced. Please contact Xbox support at the following address: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) uparrow.gifBack to the top Additional supportPlease visit the following Web site for information about how to contact Xbox support: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Dec 05, 2010 | Microsoft Xbox 360 Controller
Xbox controllerwirless wontconnect to pc
To connect the controller to a computer that is running Windows XP SP2 or a later version of Windows, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that the Xbox 360 Wireless Gaming Receiver for Windows is plugged in to your computer.
  3. On the Xbox 360 Wireless Gaming Receiver for Windows, press and release the small round Connect button.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. The Ring of Light on the controller spins and flashes one time, and the light on the Xbox 360 Wireless Gaming Receiver for Windows flashes. When the controller is connected, the Ring of Light on the controller remains lit and indicates the position in which the controller is connected.
Note If you want help connecting an Xbox 360 Wireless Controller to your personal computer, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
Jan 07, 2010 | Microsoft Xbox Console
Will it work
hello!
yes, the router will work with your pc and xbox 360.
You have to set the internet connection first between you modem, router and pc before you configure the xbox 360. try this and see if it will work with your network
you may try this and see if this help solve your problem
to set up your modem and router:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
to set up your xbox 360:
Step 1: Power down the Xbox and connect a regular straight thru Ethernet cable from one of the numbered ports on the router and plug the other end of the cable into the Xbox™’s Ethernet port.
Step 2: Power on the Xbox without a CD in the tray and the Xbox Dashboard should appear.
Step 3: Select Settings and press A on the controller.
Step 4: When the Xbox screen appears, select Network Settings and press A on the controller.
Step 5: When the Network Settings screen appears, select IP Addresses and press A.
Step 6: Under Configuration, select Automatic and press A on the controller. Take note that the IP Address being shown will be the Xbox’s IP Address. Press B to return to the previous screen.
Step 7: When the Network Settings screen appears, select DNS Servers and press A.
Step 8: Under Configuration, select Automatic and press A on the controller to save the changes. Press B to return to the previous screen.
Step 9: When the Network Settings screen appears, select PPPoE Settings and press A.
Step 10: Under Configuration, select Off and press A on the controller to save the changes. Press B to return to the previous screen.
Step 11: Once the Network Settings appears, select Connect and press A to test the connection.
Apr 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
Xbox 360 Vontroller makes my audio fuzzy
same problem here. searching for a solution to this problem is like running around in circles. I'm getting to the point where I'm about to go out and buy a decent sound card and hope it works. If it doesn't I'm going to return this POS and go back to good old Logitech equipment.
Oct 24, 2007 | Microsoft MS Xbox 360 Common Controller...
Xbox 360 Controller for Windows causes fuzzy sound
Found a solution! Came here to post it, since I could not find the solution ANYWHERE on the internet...
Using an Xbox 360 controller or any other Xbox 360 peripheral with 95% of USB sound cards or headsets will produce HORRIBLE sound input and output. It sounds like a robot has swallowed and spat back out the waveforms. Even if the 360 peripheral is removed any USB audio devices plugged in after the fact will still sound corrupted until a fresh reboot without the 360 peripheral plugged in.
I believe that the problem is somehow linked to the "generic root hub" driver, which hasn't been updated since 2001, thanks M$.
The solution (pick one of 3):
As long as the 360 peripheral is on it's own internal virtual root hub it will not interfere with other devices. You can force it to use another root hub by doing ONE of the following:
1) Fill up your usb ports with other devices till it shifts to using a secondary root hub, then plug in the 360 peripheral. This could take up to 10 USB things, depending on your motherboard and the maximum devices on each root hub.
2) Use an extra internal PCI-USB card for the 360 peripheral.
3) Use an extra external USB hub for the 360 peripheral.
NOTE: A reboot is usually required to clear up the driver's confusion.
Xbox 360 wireless controller
You must sync the 360 with your controller. Turn on your 360 and your controller. Push the little black button on the front of your console, then hold the little tiny button on the top of your controller for a few seconds. This should sync them.
May 19, 2007 | Microsoft MS Xbox 360 Common Controller...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
