Question about RCA F19240GY 19" TV
Picture scrambled periodically
Hello, The picture in my RCA TV is getting scrambled time to time in random parts of the screen. It looks like some portion of the screen is getting horizontal deflection to the right. It appears randomly in different places. Hitting the TV helps to resolve the problem and it may work Ok for 1 minute or for 1 hour then it gets scrambled again. Also periodical thin white diagonal strips appear and disappear with random spacing. Thank you.
    Top Expert:
  • RCA Master
  • 76,016 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Jun 29, 2017
  • 520 Answers
SOURCE: rca 27F554T
The text box function of the closed captioning is on. There may be a button on the remote to turn it off or you may have to go into the menu to do it.
Posted on May 14, 2008
jerryg50
  • 1689 Answers
SOURCE: RCA pix tearing horizontal lines
Get an ESR meter and check all the electrolytic capacitors in the set! I am sure you will find many decoupler and coupling capacitors that are on the edge or too high in ESR.
Jerry G.
Posted on May 25, 2008
SOURCE: TV turns off after short period off time
I have this problem as well-have to keep the house cold enough to keep it on.  I also have a box fan blowing into the right side vents (the side OPPOSITE the built-in dvd player).  It helps a lot to have the fan there, but if you put the fan on the left side vents you will have much more frequent shut downs.
Posted on Sep 04, 2008
  • 71 Answers
SOURCE: No picture, but has audio
It could possibly be a protection circuit in your tv that protects it if something is not functioning properly. from what is described, it could be anything from overheating to even a bad power supply! I would have someone look at it. Good Luck!
Posted on Jun 11, 2009
nfandres
  • 168 Answers
SOURCE: RCA 27 in has white horizontal line going through the middle
this symptons is caused by a breakdown in the vertical deflection circuit. hence, the trouble may be in the vertical oscillator, amplifier or output circuit. in most modern tv the vertical ic is usually composed of these said circuit inside. the ic have many pins, standing on a heat sink and smaller in size. try to check also the capacitors surrounding it. sometimes leaky capacitor may cause this problem. good luck!
Posted on Aug 16, 2009
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
Nov 30, 2012 | Samsung LNT5265FX 52 in. LCD Television
Westinghouse Flat Screen Goes Blurry/has Scrambled Picture
tried first with re seating the lvds cable in the t-con board, the t-con board is mounted covered with metal shield. if can get with fixing the cable, then your t-con board has defective component parts.
Aug 13, 2012 | Westinghouse Televison & Video
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
Periodic color scrambling - out of focus. Seems as though the different colors separate and get out of focus.
Ur tv is having a convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 50GX30B 50". Rear Projection...
I'm connected to a dish network receiver and the picture was good until my son tried to plug in his playstation 2. Now everything is back to the way it was originally installed except there is a scrambled...
Hey there. You want to make sure that the cables are tight on the back of the receiver and also that the tv is on the correct channel or input. Sometimes, if the tv is on the wrong input, you can get the picture, but it will look scrambled. So if you are in the room with the receiver box, you want to make sure that the tv is on channel 3 or 4, and sometimes on an input like Video 1 or 2. If on the secondary tv, you will want to make sure that the tv is on channel 60 or 73. I hope that this helps. You can follow this link below if you need more clarification.
http://www.dishnetwork.com/SupportSection/bbs-screen
Becki Barned
DISH Network Customer Service
Nov 16, 2010 | Insignia IS-LCDTV32 32 in. Television
My Westinghouse LTV-27w6-HD picture is scrambled periodically
Before you bother to read the text below, you might be better served looking at this thread:
Westinghouse troubles
If you aren't nauseated yet, continue with my original reply:
If the picture seems 'pixelated,' broken up into randomly sized and placed blocks, then it is losing synchronization with the digital signal coming in. This is certainly repairable and may be due to lousy assembly quality rather than a failed part. Most of our modern sets are assembled by robots but there is a degree of manual soldering still to be done and this can result in 'cold' solder joints that can fracture and fail due to heating and cooling of the innards of a set.
Unfortunately, unless you have a semi-retired TV service man in your neighborhood who is already financially independent, the labor costs could run fairly high for this kind of service since it requires methodical searching of the circuitry and could eat up some time.
Jul 24, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Feb 02, 2009 | Mitsubishi WS-55809 55" Rear Projection...
TV picture scrambled and getting worse
This can be a fault in the tuner, IF, or primary part of the video processing. With age and use some of the parts, and especialy capacitors, in these sets can become thermo sensitive and unstable.
To service these types of faults can be very time consuming. On top of this would be the cost of the parts.
Considering the age and type of set that you have, I would suggest that it is time to be looking for a new set.
Jerry G.
Apr 21, 2008 | Toshiba 50H82 50" Rear Projection...
Picture distorted
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 08, 2008 | RCA P46812BL 46" Rear Projection...
Static on picture
The more you hit the set and wait to get this problem fixed ,the more its gonna cost ya. Your problem is a very common one for RCA. Whats happening is theres several grounds around the tuner sheilds and tuner covers that are intrmittanly going bad because of the differant types of materials they used for the sheilds and covers , so the metals are all reacting differantly to the solder ing in the set. This set if not fixed right away will cause the eeprom to go bad and or the vertical swwep Ic to fail. The repair shouldnt cost more then 125 to 175 bucks or your getting ripped off!! Happens all the time . Good Luck
Jun 16, 2006 | RCA G36788LV 36" TV
Televison & Video Logo
43 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
