Question about Jwin JX-MP88 MP3 Player
Can't play DRM files, my player just skips over them
My jWIN JXMP88 is supposed to be able to play protected (DRM) music files, but it just skips over a few, stops on one track and then keeps skipping through the entire folder. How do I circumvent this, or, how do I fix the files?
2 Suggested Answers
SOURCE: I don't know how to put music on my mp3 player it came with a cd but I still can't get it......
I really don't know how this mp3 player works but I have provided a link to download the correct manual for your mp3 player.
and to download music, I want you to download MP3 Rocket. it is a good software to download music, videos, etc.
use these links:
Good Luck
Posted on May 26, 2009
  • 148 Answers
SOURCE: why do my mp3 files have skips when transfered to
hi if the mp3 uses a media card that skips try using a different product of another card or better still reset the mp3 player to the factory settings
Posted on May 31, 2010
0 characters
1 Points
How do I get itunes music on my mp3?
Check the settings in your Windows Media player under RIP for MP3 out put. Start by right clicking out next to Now Playing, this will bring up a context menu, look for -> Tools -> Options -> Rip music tab set up your out put to MP3 and the Folder you want to put it all in. Next put in a cd you want to rip to MP3 and let it do it's thing. Next hook up your MP3 player to your computer, and finding your music folder under windows explorer. Copy the files and drag them on to your player into a music folder. Done, go play.
Dec 25, 2009 | SanDisk Sansa m240 MP3 Player
My philips gogear mp3 player won't play my music because it says that the DRM licence is not available, how do I solve this problem?
Hello Friend,
Your player does not support copyright protected music.
To avoid this error, you can:
  • Download music which is not subject to copyright protection.
  • Deselect the option Copy protect music and click OK before you start ripping music from CD.
Best Regards,
Oct 30, 2009 | Philips GOGEAR SA6045 MP3 Player
How do i download itunes onto my sony walkman
you cant put itunes on a sony walkman if your talking about putting music that you've gotten from itune then you need an aac to mp3 converter
Oct 05, 2009 | Sony Walkman NW-A808 MP3 Player
Music files on MP3 player not playing due to license problem
This player was made before the advent of the DRM license system. You will have to use mp3 files or UNPROTECTED WMA's. DRM-license-protected WMA's - which is what most music services use - will not work on this player.
-Tha Mp3 Doctor.
Mar 02, 2009 | Philips GoGear SA178 MP3 Player
Highschool mucial mp3 won't download music from my computer
The nameless mp3 player that you have is probably not capable of playing DRM-protected songs. Double-check the songs that you have downloaded from Limewire, and see if the 3 songs that you ARE able to play are in mp3 format. If so, only transfer songs in mp3 format to the player. DRM-encrypted WMA's and iTunes (AAC) songs will not work.
-Tha Mp3 Doctor
Jan 06, 2009 | Jwin MP3 Player
Thge SA6045 does not support DRM protected files. If you are downloading these files from the internet, then you'll have to look elsewhere for files.
If you are ripping your own CDs to .MP3 or .WMA with Windows Media Player, then you need to change a setting in Windows Media Player.
Open Windows Media Player. If visible, click on "Tools" then options. If the menus are not visible, right-click at the top of the Media Player Window, then select "Tools" and click options.
Click on the "Rip CD" or "Rip Music" tab (depending on version).
Remove the tick from the box next to "Copy Protect Music" (or similar)
This will stop DRM protection on any further tracks ripped.
You will need to rip any DRM tracks again.
Apr 25, 2008 | Philips GOGEAR SA6045 MP3 Player
Acoustic solutions
Remove the DRM encryption by buying DRM Removal software (I have not found a free one that still works).
Otherwise, you will have to download only non-DRM protected songs.
Mar 08, 2008 | iLO (2 GB) MP3 Player
My SA6025 damaging mp3 files!
Make a note of skipping tracks & check these tracks play ok on the PC - this will rule out corrupted tracks.
Skipping of entire tracks can be due to DRM copy protected tracks (purchased on-line). Some players will not play DRM tracks.
You can check for protected tracks.
  • In Windows Explorer, go to the folder where the tracks are stored on your PC.
  • Click on View -----> Details
  • Right click on the header bar in the right hand window and select protected. (If protected is not listed click on More)
  • Tracks will be listed with No or Yes under protected. Check your skipping tracks are listed as No, under protected.
If none of this helps, install and run the Philips Device Manager. Select the repair / restore option and follow the on-screen prompts. This will format the player, ruling out a corrupt file system on the player, and re-load the firmware.
Mar 02, 2008 | Philips SA6025 Digital Media Player
My Sansa skips the songs I put on it, what can should I do
I restored settings to default factory settings and has been working and not skipping the songs. Restoring to factory settings does not delete any of your data/songs
Nov 27, 2006 | SanDisk Sansa e250 MP3 Player
Mneumonic skips over songs
MP3 players i have seen so far are only able to play WMA,Wav,MP3 files. Other files are skipped. Also, there arent many MP3 devices that can play DRM protected Files. Your might be it.
Nov 07, 2005 | Nefertech Mnemonic (128 MB) MP3 Player
MP3 & Digital Media Players Logo
22 people viewed this question
Top Jwin MP3 & Digital Media Players Experts
isaac johny
isaac johny
mac colar
Are you a Jwin MP3 and Digital Media Player Expert? Answer questions, earn points and help others
