Question about Lite On Televison & Video
I have a DVD Player/Recorder . The door to the dvd won't open dvd stuck in it.
    Sergeant:
    Champion:
  • 304 Answers
You can insert a needle in a hole in drive - it will enable emergency eject. Be carefull.
There should be a lil hole in the front of the drive under the tray, stick a paperclip in there to get it open.
Posted on Nov 23, 2008
My Samsung DVD/VHS recorder the DVD won't close after playing DVD
Never force it, just use the remote.
If it won't stay in, unplug the unit and wait a while.
I think we get viruses from the TV signal which might be temporary (hopefully).
Apr 24, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
Mar 21, 2012 | JVC DVD Recorder - VCR Combos: DVD...
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
Tne dvd door will not open
These are instructions to open door if DVD is jammed or the DVD recorder wont open.
Unscrew the 7 cover screws and the 2 foot screws. Remover player cover.
Pry the front control cover off from the top of the player and not the bottom with a thin screw driver paying attention not to crack or break the tabs. Just lift them enough to clear the hooks.Then lower the cover withut removing it so you can gain access to the DVD front internal bezel.
On the left side of the DVD recorder there is a notch with a lever in it. gently push on it as this is the release for the DVD door. Remove DVD from tray and close.
Re-install all covers and screws. Machine should work after this.
Jan 17, 2009 | GoVideo VR2940 DVD Recorder/VCR
The Dvd's door keeps opening and closing
Did you drop the dvd player or bump it at all? if not there is a small object stuck in the tray housing(more than likely) also see if the tray is off kilter especially if it's closing then opening. It's really hard to tell w/out seeing it but that's probably what's wrong.
Aug 27, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Dvd door will not open
My trutech DVD player door would not open.
Jul 08, 2008 | Panasonic DMR-ES40VS DVD Recorder/VCR
Stuck dvd
you need more details. DVD Player? What model, etc
Jun 13, 2008 | Toshiba D-VR4 DVD Recorder/VCR
DVD locked in and door is not opened
might have stuck inside...u got to open up the system onlly
Apr 01, 2008 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
147 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
