Fellowes DS-1 Clicking Sound
I was shredding a large amount of papers and had a few jams but it went through. The the shredder stopped working. I thought it overheated and unplugged it and let cool down for a while. I plugged it back in hours later and now the shredder works in reverse but in the auto on position, it does not work and gets a clicking sound. Can you please help?
  • drugmaven Feb 21, 2009
    DS-1 - Used it for a big job -- intermittently shredding old files, but not on for mninutes at a time. The next time I went to use it, it would work in reverse but nothing would happen otherwise, even though the sensor light would go on. I had this shredder just over a year, so I'm not sure Fellowes will do anything about it, but considering how little I used it, I'm very, very disappointed and hate to have to send it to the landfill.
  • cttho May 08, 2009
    i had the same problem, it would reverse but not forward and the sensor light is still on
    i let it rest for a month, and it starts to work again
    i realize this machine has stress and mood, you need to comfort it, clean it dust it, before use. i know it sounds weird. at least it works for me
  • 59 Answers
It means that one of the gears is most likly missing or damaged teath
Posted on Nov 29, 2008
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Shredded a few sheets of paper. clicked off. Have power at outlet. No damage to cord or connections. No auto reset of internal overload protection, amount of paper shredded far too few to trip...
Hi, make sure the cutters are not jammed with paper. To reset turn the unit to reverse for 2 seconds then auto then off. Allow to cool for 25 minutes then retry. Also make sure the base is locked in properly. Hope this helps, regards Phil.
Jul 08, 2011 | Fellowes Office Equipment & Supplies
OUR FELLOWES CROSS CUT SHREDDER WILL KEEP ON RUNNING AFTER THE PAPER HAS BEEN SHREDDED. ARE THERE SENSORS THAT COULD POSSIBLY BE COVERED IN PAPER DUST?
If you look into the slot you feed the paper into, you should see a two little bumps that are facing each other in the center of the slot. These are the sensors that tell the unit to turn on/off. You can try cleaning them with a paper towel or long q-tip. If this does not fix it, then the sensors will have to be replaced. Most Fellowes machines have a 3-year warranty, you can call Fellowes at 1-800-955-0959 to see if yours is under warranty.
May 25, 2011 | Fellowes Office Equipment & Supplies
Shredder stops in the middle of shredding and won't shred.
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Jan 21, 2008 | Fellowes 220 Powershred Strip-Cut Shredder...
Motor not shutting off in Fellowes Powerhouse C-14 shredder
this is an issue with your paperfeed sensor. You need to call Fellowes at 1-800-945-4545.
Dec 18, 2007 | Office Equipment & Supplies
Royal Shredder
there is a small micro switch in about the middle of the paper slot, make sure it is not jammed, it should move freely and make a small clicking sound with the power off.
Jan 26, 2007 | Fellowes S701CM Shredder
609 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
