Question about Elektra Microcasa S1 Coffee Maker, Espresso Machine
I'm looking for Elektra S1 Owner.s manual
Hello, I've just bought an Elektra S1 at an an antique auction for $50.00. Can you believe it.
I want to know the proper pressure the guage should be reading and the other need to know and nice to know stuff. Thanks,
Stewart
    Novelist:
  • 137 Answers
If you have 2 gauges, one shows from 0 up to 3 bar second from 0 up to 16 bar.
  1. the gauge o - 3 shows steam pressure and it should be from 1.1 up to 1.5 bar
  2. if you have second gauge you look it during brewing coffee, it should be from 7 up to 9 bar(it shows the pressure of pump.
anyway becouse it is old machine you should compare the gauge with new one(ehamle for the steam attach to steam pipe one gauge and live valve open) than you will know if it is showing true values.
Posted on Mar 31, 2009
Hi i" ve bought on
This may help. If it's not the exact model you have it will at least get you started as subwoofers are pretty much teh same for connection and operation.
http://www.wharfedale.co.uk/Portals/0/PDF_Data/Manual/DIAMOND9_range.pdf
Others here...
http://www.wharfedale.co.uk/Support/Download/Manuals/tabid/71/Default.aspx
May 06, 2011 | Wharfedale SW150 Subwoofer
I live in Helsinki and have a great Elektra SX I bought in Italy in 1993; it has worked well for 18 years. Today, both pumps work--water flows to the coffee cup area and also flows through the side...
Hello, Lucas -
I have not found any kind of repair or replacement part information (for Finland) regarding Elektra coffee and espresso machines. It seems they manufacture their machines to last a long time and keep tight control on repair.
I am answering from the USA and am having difficulty in finding a repair center for you in Finland.
Therefore, I suggest you contact the Elektra company directly. This is the link to the Elektra home page:
http://www.elektrasrl.com/en/company/
If you scroll to the bottom of the page, you will see an email address (in the lower left corner) you can use to send a message asking about repair service to your machine.
Best wishes.
Mar 03, 2018 | Elektra (SX) Espresso Machine & Coffee...
I want to get a user manual for the skype wp-S1 cell phone please kindly help thanks
If you cannot find a user manual in English, I've found a website that offers one in Italian.
There is a work around for this. What you'll need to do is download the Italian user guide to your PC. After opening the PDF file (the manual) click and highlight the paragraphs (or any word) then right click and select copy. (Up to 2000 characters at a time.)
Then, go online to this website: http://translate.reference.com/
There, you can right click and paste the information from the manual - section by section.
You can download the manual here: http://safemanuals.com/user-guide-instructions-owner-manual/SKYPE/WP-S1-_I
Feb 03, 2011 | SKYPE WP-S1 Cell Phone
I have an Elektra s1 espresso machine that is giveing me problems. I turn the machine on without any water in it, when I realised that (like an idiot) I poor same cold water in it.(the elements were...
From the User Manual:
If the machine was switched on by mistake without having filled the water circuit, the heating element safety device might have been activated.
This device protects the electric heating element against damage due to momentary overheating caused by lack of water.
Proceed as follows:
1)
Proceed as indicated in chapter "E STARTING UP THE NEW MACHINE FOR THE FIRST TIME".
2)
Check that the machine heats up correctly: if it does not, switch off the machine by putting the on/off button 1 to OFF and pull out the plug.
3)
Remove the yellow plastic cap located under the bottom of the machine.
4)
Insert a sharp pointed object into the hole left by the yellow cap and use it to press the small underlying button.
5)
Refit the yellow cap.
6)
Connect the plug to the power socket and switch on the machine by putting the on/off button 1 to ON. Check that the machine heats up correctly: if it still does not work properly this means that the heating element has been damaged; have the machine repaired by an ELEKTRA Service Centre. http://www.elektrasrl.com/en/wp-content/uploads/sites/2/2014/09/CASA-USER-MANUAL-EN-0609.pdf
Oct 02, 2017 | Elektra S1C Espresso Machine
Looking for a source for wheels, pedals, front fender, grips & paint to restore an old radio flyer classic red tricycle (10)
Antique dealers,junk dealers,toy stores,auctions,old farms (seriously...my dad has so much junk in his old barn it's pathetic)on line toy stores,and on line antique dealers.
You might want to start with the radio flyer site.
1-800-621-7613 ask for Radio Flyer's customer service.
Hope this helps.
Sep 14, 2009 | Radio Flyer Classic Red Tricycle 10"
Replacing orings on glass level indicator
Not hard to do. Unplug and drain the water. unscrew the frothing wand and tip the machine gently over a sink to drain the water in the system. Then using a box wrench (don't use an adjustable wrench or poorly fitting tool) remove the water reservoir. THen you can unscrew the pressure gauge easily. At that point, the glass is exposed. Gently twist until it's free and pull the glass up and out. When you are replacing the white Orings, a small bit of olive oil on the inside will help you insert the glass back into the orings. Then replace all the components.
Apr 13, 2009 | Elektra Microcasa S1 Coffee Maker,...
Elektra Microcasa a leva
You will need a 120/220V transformer for starters. That will make the Italian coffeemaker compatible with American outlets. The good news is that you can't do harm by plugging a 220 into an American outlet - it will just not give you enough power to run the machine.
I doubt that you can still get parts - I've seen used ones that still work on sale for anywhere from $1,000 to $3,000 - not cheap.
Here is all the contact info for Elektra - they are definitely still in business:
Elektra s.r.l. - Italian Espresso Coffee Machines
Via A. Volta 18, 31030 Dosson di Casier (Treviso) Italy - Tel +39 0422 490405 - Fax +39 0422 490620
Url: www.elektrasrl.com - Contact: info@elektrasrl.com -
Mar 11, 2009 | Elektra Microcasa S1 Coffee Maker,...
Can't get my Cannon zr 90 to work, there's a flashing red light in viewer
yes, I found the manual downloads on Canon's webpage. I wish I could figure out how to transfer my tape videos to a computer. I bought the $50,00 DV-1394 cord and nothing happens--computer doesn't recognize the camera.
Mar 15, 2008 | Canon ZR90 Mini DV Digital Camcorder
Elektra Microcasa S1 Coffee Maker, Espresso Machine Logo
275 people viewed this question
Top Elektra Coffee Makers & Espresso Machines Experts
Jaime Hernandez
vilhj
Level 1 Expert
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Elektra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
