Question about Microsoft Xbox 360 Console
One Red Light in cpntroller number 4
It keeps blinking and says system error go to xbox 360 support
  • fares75 Nov 23, 2008
    One Red Light in cpntroller number 4 problem and displays error message and e73
  • 63 Answers
Steve, what error code are you getting? Go here and find out what your error code means. http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Posted on Nov 23, 2008
My xbox only blinks red in middle then fan kicks on and system shuts down
The red light next to your Xbox 360 power button indicates that your system has detected an error. As to what that error is you will need to follow the link below to debug.
http://support.xbox.com/en-US/xbox-360/system/flashing-lights-solution
Aug 10, 2015 | Video Game Consoles & Games
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Blinking red light.Checked all cables. I replaced Hard drive...still problem exists. Wondering if power supply could be problem
When one light from the four lights ring itself changes from green to red, it means that a general hardware failure has occurred or is imminent. Blinking of one red light with an error message like E66, E67, E68, E71, E74 or E77 means a repairable problem while the one red light blinking without error message means some critical or irrepairable problem. The problem can be avoided by restarting the Xbox 360 console but if you have not received any error message with one blinking red light then the problem is irrepairable. The console will behave the same way and you should understand that one or more of the hardware components in your console have stopped functioning due to hardware failure. If you receive an error message with one red light blinking then the problem is reparable and the system will definitely start working. It means that there is some hardware problem with the Xbox 360 console connection occurring due to the misplacing of cables in the ports. Turn off your Xbox 360 and disconnect all cables, now reconnect the cables and switch on the Xbox hope this helps.
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
Xbox one blinking red light.. 1 not 3,, first time i seen this, fixed many ps3 ylod,, is it the same fix? looking for help here or a good link on repair info
When you get one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Feb 06, 2010 | Video Game Consoles & Games
My xbox360 keeps blinking red green why
is there something not plugged in right?
Nov 18, 2009 | Microsoft Xbox 360 Console
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
Sep 20, 2009 | Microsoft Xbox 360 Console
Red light blinking system error E74
this might be a hardware failure. try turning it off then back, or try keeping a fan on it when you play on and if that doesn't work call 1800myxbox there you'll find step by step instructions to send it down to texas and get it fixed. if that happens three times you will recieve a brand new xbox 360 that has that problem fixed. also keep in mind to keep your hard drive before you send it to be fixed. i really hope this helps with your problem
-good luck
Jul 14, 2009 | Microsoft Xbox 360 Console
Xbox 360 with 3 blinking red light
The xbox keeps blinking the red light and it doesn't show anithyng on the screen.
Oct 19, 2008 | Microsoft Xbox 360 Console
Won't load game keeps blinkng red light
If the XBOX 360 is blinking the color RED in three of the four quarter of the ring around the power button, you will have to contact Microsoft for a replacement. This is what is known as "Red Ring of Death." You can find plenty of information on it if you Google it.
Click HERE for a video of the Red Ring of Death.
Click HERE for Microsoft's support system for the XBOX 360 and get in touch with Microsoft to get your replacement started.
It's the ONLY way.
Good luck.
Cyryl
Dec 10, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
109 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
