I have set lock pin code for my PDA(frst time set)..when i off the phone n on back,the screen is only appear windows mobile and icons at the top side(battery,coverage n so on) but icon 4 menu start is not appeared..it continues like that even i try to off the fon..i can receive the calls n answer it..but i cant read the msg even the sound of receiving msg formed..what should i do?
Hiposting of the unlock codes in this site is illegal .. sorry for inconvenience ...
but i can give information on how to do on your own by alternate method ..
download the firmware for your N73 handset from the net (the firmware which supports your restricted network )
after that replace the firmware this solves the problem ...
There is one more way :
you can go the technician the technician will be having the DKU series cable which is used to unlock the mobiles,remove security codes,to install firmwares etc ... you can take your cell to him he will do that .. any way it not all costly it is cheap ...
sir if you rate inapropriate it will change my rating./please change it......please sir if you rate inapropriate it will change my rating./please change it......please
You can't post conmments that contain an email address.
ow to Enter Unlock Codes on LG KB770:
Insert an original simcard and turn phone on
Enter sim PIN if required
Enter 2945*#770#
From the menu that pops up select "SIM unlock"
Enter unlock code you received and press OK
The phone will then reboot and the unlock is complete
How to enter Unlock Codes to LG GB250 & GB220
Power on your phone without SIM card
Enter 2945#*505#
Enter unlock code and press OK
How to Enter Unlock Codes on LG GT505:
Enter 2945#*505#
How to Enter Unlock Codes on LG KP100:
1) Insert a not allowed SIM card
2) Press the unlock button
3) Enter the code
OR
1. Insert allowed SIM.
2. Booting (Request PIN Code, PIN Code enable)
3. In Idle Screen, Input the hidden number (2945#*20001#)
4. Input the number (above), go back to the idle screen
5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate:
6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:".
7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code
How to Enter Unlock Codes on LG KF390 and KF390q:
1) Insert a SIM Card from the network the mobile is locked to and turn it on
2) Insert the following sequence *#865625#;
3) Select 'Unlock USIM'
4) Select 'Network Lock'
5) Insert the unlock code
6) Reinsert the unlock code
7) Select OK. Done!
How to Enter Unlock Codes on LG Prada (e.g KE850, etc):
1. Switch the telephone on with Original SIM card inside.
2. Enter SIM pin if required.
3. Enter 2945#*8501# and press the call button (middle button bottom of the screen).
4. SIM unlock mode will appear on screen.
5. Enter unlock code
6. Select Reboot.
7. Switch phone off, and then turn back on again. Phone is now unlocked
How to Enter Unlock Codes on LG KE990 / KU990 Viewty:
1. Insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990#
3. A menu will pop up, select sim unlock:
4. Another menu will appear, select Network lock. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
How to Enter Unlock Codes on LG KG245 (Vodafone Australia):
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Optional Step: If the SIM card has a PIN, enter your PIN number
4. Wait for the phone to power up then enter 2945#*7101#
5. Select Menu , then go to Settings > Security > SIM Lock > Network
6. Select Deactivate and enter the 8-digit unlocking code provide for your handset.
7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
How to Enter Unlock Codes on LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Enter Unlock Codes on LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM Unlock code
5. Select "OK" - the handset is now successfully unlocked
How to Enter Unlock Codes on LG U8150:
1. Switch ON your phone with a not allowed SIM card.
2. Compose: 277634#*#.
3. Go to menu "SIM Lock".
4. Enter the unlock code
How to Enter Unlock Codes on LG INCITE CT810
Power on phone with original SIM card
Type 2945#*810#
In the menu that appears select Sim unlock
Enter supplied unlock code
Your phone is unlocked
How to Enter Unlock Codes on LG F2250
Power on phone with Orange SIM card inserted
While in the Start menu type 2945#*3311#
Return to the startup screen
Press Menu key
Select Settings > Security
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
A Samsung SGH i780 can be unlocked safer and easier using unlock code. An unlock code can be acquired either from your network provider or from any reliable online source. For example, You can get the unlock code from http://www.superunlockcodes.com/samsung-i780/rs12wp9/ at low cost. Here are the steps for unlocking a Samsung SGH - i780, 1. Switch ON your Samsung I780 with a NOT ACCEPTED SIM Card. 2. Enter the pin code to simcard. 3. At the top of screen an "exclamation mark" icon will appear. 4. Click on "exclamation mark" icon. 5. The link "settings" will appear, click on it. 6. Virtual keyboard appears on screen with Enter PIN prompt. 7. Enter your unlock code.
you can enter your code in the following way. LG Android Phones
Start your LG Optimus GT540 Android Phone Click the icon to open the phone dialer Enter 2945#*540# and press send Enter the provided unlock code (which you have purchased) Click 'Unlock' , then it's done. Your LG Optimus GT540 must be unlocked now, have a good day! LG Phone Problem and Solution
samsung phone "PUK blocked Call SOS" - i have the PUK code but cant put it in as its not giving me any option other than call sos. how do i put the code in to unlock it.
Enter the Security Code, press OK. NOTE: The default security code is 0000.
Setting the PIN Code:
From the standby screen, press Menu.
Scroll to and select Settings.
Scroll to and select PIN Code Request.
Scroll to and select On.
Enter the PIN code, press OK. NOTE: Default PIN code is 1111.
Changing the Security Code:
Scroll to and select Change Codes.
Scroll to and select Security Code.
Enter the current Security Code, press OK. NOTE: The default security code is 0000.
Enter in the New security code, press OK.
Confirm Security Code, press OK.
IMPORTANT: If the incorrect lock code is entered more than 3 times the phone will display "ENTER PUK". If this message is displayed contact Customer Care.
