Question about Tecnik TKC8522 Electric Double Oven
Grill works at start then cuts out after a couple of minutes
I have a Tecnick TKC 8526/2 Electric Double Oven which is 3 Years old. When using the grill it goes off after a couple of minutes of cooking, I then switch off and let it cool a while then switch on again. some times this will work and other times it won't, also the switch (knob) appears to get hot.
would this be a thermostat problem and can I repair it myself or does it have to go back to the supplier.
Regards ****
barkencoa
  • 3463 Answers
SOURCE: grill broken only part working
You need to replace the complete element
Posted on Dec 27, 2008
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
barkencoa
  • 3463 Answers
SOURCE: fan and grill works, grill actually cooks but oven
Without a doubt this is the element that is faulty.
It is located at the rear of the inner oven compartment behind a removeable cover.
Posted on Mar 30, 2010
  • 523 Answers
SOURCE: Grill gets hot works for 5mins then switches off ,
change t stat
Posted on May 11, 2010
  • 228 Answers
SOURCE: tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Posted on Jun 05, 2010
Rcd trips after 1 minute of using top oven or grill
It could be the top oven overheat thermostat going faulty. With something like this the only way to find it is to take the oven to bits and use a test meter to see what is causing the problem. Just to let you know, on the 720, the grill works independent of the timer/clock. So if both the top oven and grill are generating the problem, that is where I would start to look.
Dec 13, 2011 | Stoves 720EF Electric Double Oven
Fisher and Paykel AeroTech Double - OD301 Electric Oven Oven not working after self cleaning
Ours have also stopped working (both top and bottom). Bought in 2003 so only 8 yrs old. Getting technician in to fix. Will post solution. Also whenever oven is heated up the display panel fades and is not visible (has been doing this for a couple of years)
Nov 22, 2011 | Fisher and Paykel AeroTech Double - OD302M...
Electric grill is intermittant or cuts out after 5/10 minutes
There are two overheat devices in the oven. One feeds the oven timer/programmer for the main oven and the other feeds the grill. If the cooling fan is running ok, then I would suspect it is the cutout feeding the grill elements that has perhaps with age is not working as it should do.
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Tecnick tck 8522/2 oven
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
Recently wired a double oven with isolator switch
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Cheers
Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
Grill broken only part working
Dec 24, 2008 | Tecnik TKC8525 Double Oven
Electric oven & grill not working no digital clock display
If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
They can be bypassed, but not recommended unless you know what you are doing..
If there is no display at all , then check to make sure you have supply to oven
Plz rate my solution.
Thanks.
Dec 16, 2008 | Neff U1661 Double circotherm super...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Tecnik TKC8522 Electric Double Oven Logo
46 people viewed this question
Top Tecnik Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Tecnik Oven Expert? Answer questions, earn points and help others
