Question about Philips CDR765 2-Disc CD Recorder
No audio The problem I seem to be having is that I plug in all the wires to the back of the unit and the unit does not seem to recognize the audio coming into it. It simply displays "no audio". What can I do. It also won't dub, it just displays "no audio" whenever I hit the record button.
    Problem Solver:
  • 30 Answers
Check line IN / OUT if properly connected,check also the kind of signal you are using ( analog or digital) plus your selector switch,make sure you selected the right source.
Posted on Jan 27, 2007
  • 112 Answers
'no audio' comes up when you use a computer grade cdr disc. Buy some audio use CDrs and it'll be fine. Google for the manual - it explains 'no audio'
If you get no or a distorted, low sound output when playing,it's likelt a failure of the op-amp on the cdr PCB.
Posted on Dec 09, 2007
Why does my unit only provide video, and no audio. Please help!
Him.. Could be a short. You should unplug your receiver and disconnect all the wires from the back, then plug them back in before plugging it back in. Might just need a reset. Also check all your wires going to the speakers. If one has got cut or frayed it could be causing the interference
Jul 02, 2014 | Harman Kardon AVR 3600
Philips fwd798 does not switch off remote does not seem to operate properly batteries are fine cd tray does not open
Remove batteries and unplug from the wall receptical, allow 60 seconds to pass in a effort to reset the processor ic, if no change check speaker wires on back for shorts, if wiring okay have the unit checked for audio output ic problems.
Sep 02, 2012 | Philips FWD798/37 Shelf System
When there's no Ipod plugged into the front USB port on my Sony CDXGT740UI it displays the usual NO DEV. When I plug my Ipod into it seems to fail to recognize the Ipod and I get NO SUPRT on the display. ...
common issue with the sony models your usb port is bad. easy fix is auxilary cable input in the front from ipod or back in the unit but cheapest is a 10 dollar adapter for fm / blu tooth streaming. theres your solution thumb me up sorry bad news bout the usb
Mar 25, 2011 | Sony CDXGT740UI InDash MP3WMAAAC Player
Garmin etrex vista screen disappearing and coming back. batteries fine, seems a commonish prob but HOW TO FIX?. Regards nav man
The best thing to do would be to plug the unit into your PC and see if it recognizes it as a device, if the unit is not recognized you will have to be sent in for warranty or repair. If the PC does recognize the unit try giving it an update using Garmins WebUpdater Software, it can be obtained ehre from this link http://www8.garmin.com/support/download.jsp.
Mar 23, 2011 | Garmin GPS
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
Cannot get power to the unit the light indicating power is out
I have the same model as you. I have two transmitters and three headphones actually. Please see below:
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones and adjust its volume as well).
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Apr 24, 2010 | RCA WHP140 Consumer Headphones
Hooking sat to car stereo
that plug at the back is not for sat radio. It is for use with steering wheel controls. You have the blue plug at rear of stereo and that is the plug for sat radio. Ericson electronics is contracted to build the sat compatible units that wire into this radio through the blue. plug. if you are using 3.5 plug audio control from a portable sat receiver, the you will need to buy an aux input cable for your stereo..
Sep 25, 2009 | Pioneer DEH-P3700MP CD/MP3/WMA/WAV...
I have boston ba745 speakers with woofer. The speaker wire coming out of the back of the woofer goes into computer and it's a wire with 2 plugs, a pink one and a green one. It doesn't appear to make any...
The green plug is the main audio plug for the unit. It plugs into the green jack{output} on the computer. The pink one plugs into the pink jack on the computer if there is one. Google the manual for the speakers and you might find oyut what the use of the pink one is
Apr 29, 2017 | Boston Acoustics BA745 Computer Speakers
Will no longer switch to sirius sat rec
My dad had a similar issue. The only way we resolved it was by unplugging the satellite receiver cable from the stereo, turn on, then off again, then plug the cable back in. Essentially, it has to re-recognize that the cable is plugged in.
Apr 02, 2008 | Pioneer DEH-P4700MP CD Player
Philips CDR765 2-Disc CD Recorder Logo
328 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
