Question about Onkyo HTR500 Receiver
LED display is off
My receiver is working fine except that the display is completely off. I have had the receiver for about four years. I don't know if it will be a costly repair or not. Any advice?
  • 4 more comments
  • Anonymous Dec 06, 2007
    I have the same exact problem--happened yesterday. I don't think the "buy a new display" is the right solution for everyone. It might only be available to repair centers, and only the technicians may be able to install it.
  • Anonymous Dec 22, 2007
    Have the same problem...any solution out there?
  • angelog72 Nov 19, 2008
    all of a sudden the buttons aren't working the right items. ie, when DVD is pushed, TV sound comes through. TV sound also comes through if the TAPE button is pushed. it seems all the buttons are working random outputs?? unfortunately, my dad doesn't have the manual. although, i'm gonna try and find a pdf after i post here.
    thank you.
  • benw706 Dec 04, 2008
    led display is off, will not light up. otherwise reciever works fine
  • kozas Dec 19, 2008
    Mine just went off a couple days ago. Everything else seems to work fine, but no LED display. While I'm trying to figure out what to do, I worry that I'll accidentally hit the wrong remote button and put me in a mode that I cannot get out of with the still working onscreen menu.
  • aa7679 Feb 02, 2009
    Screen quit working.
    Genius:
  • 1,175 Answers
The service manual might help, if you're a tech, but the circuit board assby is : onkyo part # 1A928503-1A also called NADIS7403
I would have a technician check the power supply lines for the circuit card and the solder joints for the flex cables to the circuit card.
I would also suggest unitedradio.com
Happy New Years
Posted on Jan 01, 2009
  • 135 Answers
Buy a new display?
Posted on Mar 31, 2007
  • ted dux Oct 02, 2008
    service manual here:
    http://www.eserviceinfo.com/downloadsm/2...
    buy part here:
    custserv@unitedradio.com
    1-866-779-1405
    easy to replace.
I just bought an led light set for my new diamondback bike. Which is fine except I don't know how to attach it to the bike the pieces that came with it only attach together. Am I missing something?
If you feel pieces are missing, return the unit and get a new one. Aside from that, you would have to improvise a fastener to attach to the frame or handlebars. 7_16_2013_10_17_55_pm.jpg
Jul 15, 2013 | Cycling
When pluged in the On/Standby LED will light. When pressing power the On/Standby LED with flash then go solid but nothing apears on the display. I can select what speakrs to use (A or B). All the LED's...
Most likely the unit does not receive power from main transformer. Possible several reasons:
- bad power transformer
- bad main internal fuse 7-8amp. Bad fuse most likely because of one of the channel is blown and shorts the power, so before installing new fuse good idea to check all channels by meter or at least visually for burned parts
- bad power relay
- bad connection, cracked soldering joints
Jul 18, 2011 | Denon AVR-1602 Receiver
Harman/kardon avr 247 no audio or LED display on the reciever
I've had the exact problem. HK in the states is no help, you need to deal with a company in Montreal (Jan Industries). Regular techs are unable to fix it without schematics that only authorized dealers have and the manufacturer. This problem happened to me just after 2 years and outside warranty. I've bought a Yamaha today.
Apr 01, 2009 | Harman Multimedia AVR 247 7.1 Channels...
Denon AVR 4802 Receiver w/ Denon DVM 4800 DVD player - video fail
no the problem is at the plasma you will have to change the setting back to the scale range that will accept the signals from the Denon, see Plasma's manual for instructions
Jan 27, 2009 | Denon AVR-4802 Receiver
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
RCA RTD315W Receiver/DVD LED display
If you are referring to the information display, it doesn't activate until you take the system out of standby (the bright blue LED at the corner is shining). When you hit the OFF button (on the system or the remote) and the blue LED shuts off, your info display comes on and says WELCOME.
Dec 27, 2008 | RCA RT2500 System
Onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Oct 31, 2008 | Onkyo TX-SR602 Receiver
Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Feb 21, 2008 | Onkyo TX-SR605 Receiver
STR-DE597 Display is not visible
Try a complete RESET by completely switching OFF mains power and leaving for at least 40secs. before commencing a new setting-up procedure.
Let's know if this does work it back to normality!
Aug 04, 2007 | Sony STR-DE597 Receiver
Onkyo HTR500 Receiver Logo
330 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
