Question about GE Profile GCG1700LII 15" Built-In Trash Compactor with 1.4 Cu. Ft. Capacity, Fully Integrated Door ...
Fitting an integrated fridge freezer!
Hi, we have just bought a hotpoint hmb312a integrated fridge freezer(70/30) and i'm having problems fitting the kitchen door to the appliance as there does not seem to be any holes to attach the brackets to the freezer door.any help would be much appreciated. Gareth.
  • Anonymous Mar 19, 2014
    no holes in the door to fit the brackets to
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Posted on Aug 01, 2009
How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Oct 06, 2014 | Refrigerators
Water gathering in pipe in fridge and overflowing into fridge
Hi you will find this is a common problem bits of food get into this outlet and it gets blocked you should have got a small tool with the freezer when you bought it if not use a small screwdriver or smilar item to unblock the hole and you will find this will solve the problem
Mar 17, 2011 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
I have a Hotpoint HMB313I integrated fridge freezer. When I open the fridge door no light comes on. Should there be a light in the fridge? If so, could you tell me please where the light(bulb) is located...
Hi!!
The light bulb is usually located in the center top of the fridge box, you may need to get on your knees and look up to see it. They usually just screw out, in case there is a plastic cover, just squeeze it and remove it. The replacement bulb can be found at Walmart or KMar it is call Appliance Bulb.
Good Luck!! Don't forget to rate this post!!
Jul 18, 2010 | Hotpoint Refrigerators
Re-gas Hotpoint FFA64 Fridge Freezer
only certified tech's can regas refrigerator freezers and usually find there are other problems that caused the leakage . PAY to have it tested
Jan 28, 2018 | HP Refrigerators
Hotpoint fridge freezer / howdens kitchen - no instructions!!
Luckily the hotpoint helpdesk admitted that the instructions for hanging the kitchen doors does not come as part of the standard instructions. There should be a seperate piece of paper with these instructions.
After some to'ing and fro'ing they managed to email me the required diagram.
Feb 05, 2009 | Refrigerators
Fridge part of fridge freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 16, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Hotpoint FFS70 fridge problem with draws.
Not sure which drawers you are talking about BUT have you tried switching over the two crisper drawers? They are not interchangeable, i.e. there is only one way the will fit inside the fridge.
Jun 12, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint ff175b fridge freezer
I had the same problem. Hotpoint told me it was the electronic card, and I waited 3 weeks for them to get one in stock. Just been fitted and made no difference, though the Hotpoint man told me it was fixed. I have just spent half an hour "shaking and whaking" various bits at the back of the fridge freezer and the compressor has finally kicked into life.
Concentrate your shaking and whacking on the black square thing to the left of the compressor.
Going to quit my job and become a freezer repair man.
Nov 28, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fridge is freezing food
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Aug 15, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
GE Profile GCG1700LII 15" Built-In Trash Compactor with 1.4 Cu. Ft. Capacity, Fully Integrated Door ... Logo
2,766 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
