Question about Remote 2 T-harness
Pasanger side door will not lock with aftermarket alarm system
The passenger side door will not lock when i try to use the alarm/keyless entry remote and i have to manualey lock the door but the alarm will come on any suggestions??????????
  • 1,602 Answers
THE DEVICE THAT CONNECT THE ELECTRONIC WIRE DEVICE TO THE MANUAL DEVICE THE WIRE HAS CAME LOOSE OR THE FUSE LINK HAS BURT OUT AND NEEDS REPLACE, NOW WHERE I LEAVE THE AUTOMOTIVE STORES WILL PUT IT ON A TESTER DEVICE FOR NO CHARGE TO SEE IF THEY CAN HELP YOU SOLVE IT, LOOK FOR CHECKER, SOME PEPBOYS, AUTOZONE,
Posted on Feb 19, 2009
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
2004 chevy malibu driver and passenger door lock problems
The locks on your vehicle are electronically controlled by the BCM - body control module . The driver an passenger door switche's are input's to the BCM . Do you know anything about automotive electronic's ? anti theft alarm remote, could this be part of the problem , No it's just a key less entry remote , nothing to do with the anti-theft .
Door Lock System Components
The Power Door Lock System consists of the following components:
• Body control module (BCM)
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• IBCM (PWR) 15-amp fuse
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch Lock or Unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation
• An automatic door unlock actuation
• A last door closed locking (LDCL) actuation
Driver and Passenger Door Unlock Operation w/o Keyless Entry
When the body control module (BCM) detects a transition of either of the door lock switches to the Unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the driver passenger door lock actuators transition to the Unlock position.
Your best bet , take your vehicle to a qualified repair shop ! Need special tool to diagnose .
Power Door Locks Inoperative
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, observe the door lock switch parameter in the Doors data list.
Does the scan tool display Idle?
YES - Go to Step 4
NO - Go to Step 8
Activate the driver door lock switch to the LOCK and UNLOCK positions.
YES - Go to Step 9
NO - Go to Step 5
5
Activate the front passenger door lock switch to the LOCK and UNLOCK positions.
YES - Go to Step 9
NO - Go to Step 6
6
With a scan tool, observe the driver door lock actuator command and the passenger door lock actuator command parameters in the Doors data list.
Activate a door lock switch to the LOCK and UNLOCK positions.
Dec 24, 2017 | 2009 Chevrolet Malibu
2008 cadillac cts key fob not working
Testing would need to be done , scan tool hooked up checking DTC'S - diagnostic trouble codes . View data etc...
Keyless Entry System Description and Operation - Active
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the door locks to unlock the vehicle. Keyless entry will lock/unlock a door or open the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message. A low transmitter battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas, such as gas stations that use pay-at-the-pump RF transponders, may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following features:
• Door lock/unlock
• Rear compartment lid release
• Illuminated entry lamps
• Panic alarm/Vehicle locator
• Remote vehicle start
Your best bet , take it to a qualified repair shop . Dealer
Feb 18, 2018 | 2008 Cadillac Cts
2008 HHR Remote Starter not working
Is this an issue with all 2008 HHR remotes??? Highly doubtful , probably the vehicles keyless entry system . Taking the vehicle to a qualified repair shop an having the keyless entry system checked for DTC'S - diagnostic trouble code's . Do you know what a DTC is ?
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the body control module (BCM) to remotely activate certain vehicle features. Keyless entry will lock/unlock the doors, or release the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message to the BCM. A low transmitter or vehicle battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following components:
• Door locks
• Liftgate lock
• Remote rear doors (Panel only)
• Vehicle locator/panic alarm
The keyless entry system has the following components:
• Keyless entry transmitters
• Keyless entry antenna
• 2 Way Advanced Remote Start RCDLR
• BCM
Guessing will not fix this .
Jan 12, 2018 | 2006 Chevrolet HHR
Bought from dealer with no keyless entry. alarm activates when doors are locked with power doorlock system. alarm sounds when we open the door. how do we de-activate the alarm before unlocking the door?
Opening the drivers door with the key is supposed to shut down the factory security but the drivers key cylinder usually goes bad. You will have to unlock the rear tail gate lock cylinder with the key and that will shut down the factory security, before opening the drivers door.Your other option is to have an aftermarket keyless entry system installed, which will open the doors remotely while shut down the factory security at the same time.
Jan 25, 2011 | 1996 Jeep Grand Cherokee
Need crossreference wiring on a 2008 dodge charger and aftermarket alarm
This link will get you 2007 which should be same. Good Luck.
http://www.the12volt.com/installbay/uploads/2007DodgeCharger.txt
Nov 03, 2010 | Dodge Charger Cars & Trucks
Power door locks do not work with keyless remote control
There are two multiplex control units - one on the driver side and one onthe passenger side - which one did you unplug? The one on the driver side is the main "Brain" while the other one is the one that houses the keyless reciever. According to the service manual, any troubleshooting of this system must begin with the one on the driver side. It can get quite involved because Honda does not provide actual troubleshooting (symptom) charts, just descriptions of the electrical connectors and what conditions should be present at each conector pin under what system condition. (each pin has to be tested to determine what is malfunctioning) The system is not capable of outputting fault codes of any kind.
Nov 08, 2009 | Honda Accord Cars & Trucks
2001 T & C van, driver side back door will not unlock. Also, I am not sure if thisi srelated but the car alarm keeps going off every few minutes ugghhh!
First, check that you're child safety lock isn't set for that door...If thats not possible then the next culprit might be the alarm FOB battery. IF, its an aftermarket alarm FOB you're in luck...changing the batt should do it...If it IS a factory alarm FOB, you have TWO choices...get a new aftermarket keyless entry system $89-129...or go to the dealer for reprogramming the remote, about $89.
Good Luck
Jun 23, 2009 | 2001 Chrysler Town & Country
I cant cut off my alarm and car wont start
is ti and aftermarket or factory system, if aftermarket look for little black button under dash or button on antenna, turn key on and press for one full second, if aftermarket unlock door with either trunk or passenger side and try again...
Jan 25, 2009 | Vehicle Parts & Accessories
Remote  2 T-harness Logo
117 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
