Question about GE Refrigerators
GE PSS26MSTASS Regrigerator ice & water dispensing problems
To all those wonderful experts,
You seem to have done a great job in helping the people in need of help for various appliances. Now, I would appreciate any help that I get from you.
I have a two and half year old GE PSS26MSTASS Refrigerator and few days ago it stopped dispensing ice and water all together. Being an engineer, I messed around a little and found that if I removed the small light bulb that lights the water/ice dispensing area, the water dispensing started functioning fine, but not the ice (no cubed, no crushed, etc).
The strange thing is when I press the dispensing panel push buttons for ice or cubed ice or crushed ice and then then try to get ice, nothing gets dispensed, but it seems like the fridge resets (goes quiet) for I think over a minute.
I started using water dispenser by removing the light bulb. But in the recent past, even the water dispenser started malfunctioning in spite of no light bulb in its holder. It goes off and on. When water dispenser is not working, if I switch off and switch on the whole refrigerator, it starts working immediately and stays working for some time. But, it goes back to non-functioning state with in a matter of about 30 minutes.
If I take the ice bin/bucket out from freezer, I can turn the augur motor with my hand. No problems there. I also see the ice maker working and forming new ice cubes in ice bin.
I am thinking "Interface dispenser asm bk" may be the issue. Could one of you help me out and let me know how I can approach this problem?
Many many thanks in advance for your help!
My GE Profile PSS26MSTASS ice maker is not working - no ice.
It could be a bad icemaker. Water should have frozen in it. Is the mold tray warm it could be stuck in a harvest mode.
Sep 11, 2014 | Refrigerators
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
The Side by Side GE Profile refrigerator does not dispense any water or ice. It worked for a short period of time but just stopped working. Also, all the options that are suppose to be lite go off when the...
Could be several problems (I'm a homeowner, not an expert). GE had a problem with the water line in the freezer door: not enuf insulation so the line freezes, hence no water flow. I would look at this first, especially if you press the water dispenser handle and you hear the pump, but no water comes out. Ditto if the ice bin is empty or the ice maker isn't making any more ice. If the icemaker is making ice but not dispensing it, then the auger (thing that agitates the ice cubes in the bin) may be broken or frozen. (if frozen be sure ice cubes in bin are loose and not frozen into one big ice cube).
Aug 13, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Our 2 door water dispensor not working. ice coming through o.k.
I followed a suggestion from one of your customers and it worked!
JKP
Jan 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My water dispenser stopped working. When I try dispensing water, I hear a clicking sound, but no water comes out. Is something frozen inside? When this has happened in the past, I've emptied the ice...
That can only be a blockage from the valve or crimped water line or a defective solenoied on the dispenser side of the water control valve part number WR57X10032
Sea Breeze
Oct 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water Dispenser works intermintently, Ice dispenser never works
Called GE Service Dept. My refrigerator was way out of the warrant period. They came out and replaced the main circuit board at NO CHARGE.
Jan 12, 2009 | GE PSW26SGRSS Side by Side Refrigerator
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
GE Model TFF24RWC Side By Side Ice/Water not Dispensing
I had that issue and a myriad of other issues with my GE side by side fridge. I replaced the control panel $100 and all three problems I had went away immediately.
1. Ice and water dispenser quit working
2. Howling noise 12 hours out of the day
3. Clicking noise
Jan 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in door stopped dispensing
We just had this happen on our Kenmore side-by-side and we had to replace the water valve and now it works great.
Aug 17, 2007 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
288 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
