Question about HP Compaq nx6110 Notebook
One of the key on my laptop keypad is not working
And whenever i try to login to type my password the key letter just keep repeating
Streambook 13 keyboard locked up. How to return it to original settings
since the laptop is only a few days old I would recommend performing a factory restore to the "out of box" state.
Jan 05, 2015 | HP Computers & Internet
Dell laptop inspiron 1720
you have something stuck under the keypad....try air to dislodge...
Feb 25, 2013 | Computers & Internet
Whenever i try to go online i cant type my whole password coz its only 1 letter i see everytime i type on my keypad
If you are not using the default browser, at the time you write the password click on the options buttion of your browser and select EDIT/FULLSCREEN EDIT then type your password. Rate my answer...
Sep 25, 2011 | Samsung Cell Phones
I password my laptop (samsung R510) and one of the key I used is not working and I got an external USB keyboard by the keyborad is not working with, what will I do to used the external keyboard
your USB keyboard may not work because your laptop has not got to the point of initiating USB at the point of booting to password.
You could try using ascii codes to eneter the key
at the point where you need to enter the key that doesnt work press your numlock button this will turn some of your letters into numbers...they should be written on the keys in a different colur...the laptop Im looking at at the moment has 4 on U, 5 on I 6 on O, 1 on J etc...
hopefully these are not the broken key..
if you look here you will see the chart that says A=65 B=66 etc in order
http://www.asciitable.com/
find the letter you need eg v=118 in lower case
type in your password till you get to the v (if thats the broken letter)
press and hold [ALT] button with num lock on and on your newley formed number pad type in the number thet represent the letter in this case 118 when you release the [ALT] key it will insert that letter.
however this only works with an extended keypad (like a full size keyboard) where the numbers are seperate not your top row numbers which is why you need your numlock on.
HTH
Richard www.2pages.co.uk
if it does then work maybe you could go into your bios and turn USB legacy support on...which may then help your full size keyboard to work too.
Jul 28, 2011 | Samsung R610-64G Laptop
I cant sign in to yahoo messenger it keeps on telling me that my user name and password is incorrect but i had already re type it 20 times but still it keeps on saying that. what shall i do? thnaks
Double check and make sure your caplock key isn't on and that you don't have a stuck key. You can check this by typing in notepad or an email, type your password and look at it. Once you see that it's typing the correct password (and correct case, ie capital letters or not) you can try copying the password and pasting it into yahoo login and see if it works then. Because you can't see a password as you type it this often helps.
Also think about if you used a capital letter or perhaps spelled something slightly different when you picked your nick name and password.
Jun 25, 2011 | Yahoo Messenger
My Dell Vostro 1510 has a problem with the key in inbetween k & h.The letter wouldnt type when I press that key but whenever I open a notepad it keeps repeating.Also when I boot my lapto there is a...
You have a stuck key on the laptop. I would purchase a new one on EBay. They are not expensive! and easy to install. http://support.dell.com/support/edocs/systems/vos1510/en/index.htm
Download the service manual for step by step instructions. Good Luck Phil
Feb 21, 2010 | Dell Vostro 1510 Laptop
Laptop compaq N2660 keyboard not working, does this have a keypad
try to boot up machine again. i suspect you keyboard just went hang.
Jul 01, 2009 | HP Compaq nc6220 Notebook
Letter key on our keyboard doesn't work when you type on it
if handy with tools you can open KB an check all traces are good
if not need to use a HB pencil to re-trace grid @ non-working key
May 08, 2009 | Computers & Internet
I suspected your keyboard is already faulty. You might need to change it. Call the service hotline for the brand of your machine and tell them to replace your keyboard.
Note: If machine is under warranty no need to pay for the repairs.
Apr 30, 2009 | Computers & Internet
HP Compaq nx6110 Notebook Logo
163 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
