Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Computer suddenly not reading external harddrive
Up until yesterday, my Simpledrive 500 GB harddrive was working just fine. Now, no matter what USB port I connect it to, my computer isn't reading it. The light lights up and the harddrive boots up when it's connected, and it seems as though it would work, but my computer can't detect anything from it. I've tried rebooting and unplugging it many, many times, but it makes no difference. My other smaller Simpletech 160 GB drive is still working, but the larger one isn't. The 500 GB harddrive is much newer as well; I've only had it about 2 months.
My computer model is an HP a1110n.
  • 2 more comments
  • mikeeee4444 Nov 25, 2008
    same exact problem except his solution didnt work for me
  • iirish Dec 01, 2008
    My western digtal load driver each time plug in but list as wd in hardware but does not list to use in explorer.
  • maraterrapin Jan 07, 2009
    I have a 320 My Book that was working just fine. Then all of a sudden, when I went to save some downloaded music to it, it no longer showed up under my computer icon.
  • lineyyy Apr 16, 2009
    same here! neither pc or mac can recognize my simpletech 500gb external drive anymore. i was using it just fine by this afternoon and then came home and it won't work anymore. does anyone have a clue?
    starting to panic here, the thing has just got my whole life inside of it.
    help us please!
I managed to fix it by unplugging the harddrive from the main electrical power source.
Posted on Nov 24, 2008
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
My external Harddrive just up and stopped showing up on the computer. I mean the lights (red and blue) are on, it just doesnt show up. i even plugged both cables into my comp, and still nothing. I noticed...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then power adapter of harddisk or your harddrive has internal issue.
Let me know if you need further assistance. Thanks for using FixYa
Oct 15, 2010 | SimpleTech SimpleDrive 160 GB External USB...
External hard drive read only on my mac?
That's a very strange occurrence, I agree with you. The good news is that one of the standard administrative applications included with Mac OS X will doubtless fix what's happened on your disk, which is that a folder permission has somehow been messed up.
The program you need is Disk Utility and you can find it in Applications --> Utilities --> Disk Utility. Then simply select the drive you want to fix:
May 30, 2010 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
I was using my harddisk for more than 2.5 years and suddenly from yesterday......when i try to access it through my computer it says format the disk...i dont know what happened suddenly.....and the blue...
do not format.....do not chkdsk....
get some data recovery software and install it in other computer with second harddrive
then run the software and recover the data in it
Oct 05, 2009 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
ST-500 not recognized with Epson CX9400 printer
Printer is draining USB power resource. Add a powered USB hub and run drive off of that.
Jul 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Hard Drive Dropped
Turn off your computer and then plug in the FreeAgent external drive. Then try turning your computer on, it should read.  If it doesn't I would go to the Seagate website for troubleshooting.
Jan 31, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
1,589 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
