If your Singer Heavy Duty 4423 is jamming when you try to sew in reverse, it may be due to a few issues:
- Thread tension: Make sure your thread tension is not too tight, which can cause the thread to bunch up and jam the machine. Try loosening the tension slightly.
- Needle: Make sure you are using the correct needle for the fabric you are sewing. A dull or damaged needle can cause the machine to jam.
- Bobbin: Check your bobbin to make sure it is threaded correctly and is not damaged.
- Machine maintenance: It's important to keep your machine clean and well-oiled. A buildup of lint or dirt can cause the machine to jam.
- Sewing speed: Slow down when sewing in reverse. Sometimes going too fast in reverse can cause the machine to jam.
If none of these solutions work, it may be a mechanical issue with the machine and it's best to take it to a professional for repair
