Question about Krups FEM2B Toast Expert 2-Slice Toaster
Krups Fem 2 outside elements not working.
My Krups FEM 2 toaster will not turn on the outside heating elements. The inside works fine. Also the Stop button does'nt work either.
  • 2509 Answers
SOURCE: Krupa fep2 toaster...
Make sure the socket you are plugging into is working by plugging in another appliance or radio etc. Check the fuse in the plug if it has one, this is the most likely problem, if it is ok you will need to do continuity checks from the plug through to the insides of the toaster to check if it is the switch or thermal fuse inside the toaster.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Posted on Feb 14, 2011
cactus bob
  • 267 Answers
SOURCE: Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Posted on Feb 26, 2009
cactus bob
  • 267 Answers
SOURCE: Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 02, 2009
cactus bob
  • 267 Answers
SOURCE: Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 31, 2009
videotransmi
  • 105 Answers
SOURCE: my toaster will not turn off. I press the toast
It sounds like the temperature sensor has malfunctioned. When the sensor reaches a certain temperature it opens the contact to the heating elements shutting off the toaster. If the unit is under warranty then take it to a repair facility for Krups. I would not allow anyone to use the toaster. If left on it could cause a fire. Take care, stay safe and good luck with your unit!
Posted on Nov 11, 2009
How to take apart the krups FEM 2 toaster
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB0QtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DFcFe1RM7clE&ei=52EIVcmcOtSqyASWvoCoCw&usg=AFQjCNHIm_2LlNFt7FJBFfYpTCTgYqGZHg&bvm=bv.88198703,d.aWw
May 17, 2014 | Coffee Makers & Espresso Machines
2001 Ford Windstar Van I am losing power to the instrument cluster. The charge l2001 Ford Windstar Van I am losing power to the instrument cluster about 10 seconds after starting. The charge light,air bag,...
All the thing's your having problems with are controlled by the computer's an communication network . (FEM) - front electronic module , insturment cluster , (REM) - rear electronic module. etc... It's probably a loose ground connection somewhere . The headlamp switch is a electronic input to the insturment cluster , the insturment cluster is hooked to the SCP - serial data network . The insturment cluster electronic's (computer ) microprocessor sends a message to the (FEM) to turn on light's , the front electronic module will then suppy a ground to the headlamps circuit turnning on the headlamps. Samething for the wipers an turn signals an horn too .
010 Ford SCP Communications
From looking at a wiring diagram i would look at ground connection G-304 . Do you know what a body ground is ?
This ground is located How to troubleshoot headlights intermittently on and off with headlights...
1down vote Basically your headlamps are controlled by a computer. The Front Electronic Module (FEM) to be exact. The FEM grounds the headlamps when it wants to turn them on. This system was an early Multiplex design that reduced wire and total circuits where the modules communicate on a single serial line, now referred to as the CAN Bus (Controller Area Network). You will likely need a scan tool to diagnosis the car, and not a cheap one, but a professional model. You many even need a factory scan tool, though I doubt if for a Ford. Outside of security theft deterrent systems they allow the aftermarket professional scan tools to access their systems.
So where do you go from here? With or without a scan tool, the grounds are a good place to start.
G303 are the main ground for the FEM.
G304 is connected via C179 (C means connector) and through S139 (S means splice)
G304 is located behind the LH cowl panel C179 is located behind the LH side of the instrument panel S139 Dash panel to headlamp junction, near T/O to C192 Front Electronic Module (FEM)
You can see the FEM, G304, and C179 in the picture below. Outside of checking the connections and wiring there is not much you can do without a scan tool.
Jun 24, 2017 | Cars & Trucks
How to take out only interior light fuse
2000 Lincoln Navigator interior lights won't turn off and now the door ajar light is on as well. How can this be fixed, I tried wd40 as suggested it didn't work HELP!
Feb 28, 2010 | 2002 Lincoln LS
My toaster will not turn off. I press the toast button, it does it's job and then pops up, but the heating elements will continue to stay on.
Nov 10, 2009 | Krups FEC212 Toast Supreme 2-Slice Toaster
Mar 30, 2009 | Krups Toaster Ovens
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Lincoln LS 2001 3.0
Fuse/Relay
Location
Fuse Amp
Rating
Passenger Compartment
Fuse Panel Description
9 10A Right Front Low Beam
10 5A Left Front Turn, Left Front Repeater, Left
Front Sidemarker, Left Front Park Lamps
11 10A Left Front High Beam
12 — Not Used
13 5A Cluster
14 10A RCM, DATC
15 5A Not Used (Spare)
16 5A E/C Mirror, Heated Seat Controls, RSM
(Rain Sensor Module)
17 5A RCM, Alternator Warning Lamp
18 20A Radio, CIA
19 15A Tilt/Tele Motors
20 10A FEM, DATC, Cluster, Brake Shift Interlock,
REM
21 10A Power Folding Mirrors
22 10A DDM
23 10A Right Front High Beam
24 5A PATS
25 10A Left Front Low Beam
26 10A Wiper Relay, Windshield Washer
27 10A Radio, Cellphone
28 5A Security Horn
29 5A Trailer Tow Ignition Sense, VEMS, FEM
30 5A FEM
31 — Not Used
32 20A Cigar Lighter
33 10A Switch Backlighting
34 10A Not Used (Spare)
35 5A Stop Lamp Signal
Oct 23, 2008 | 2001 Lincoln LS
Taking way too long to heat
Usually when an oven is slow to heat, it is because of a bad element. You can look at the upper (broil) and lower(bake) and see if they appear to have any major burn marks on them, It may just look like something spilled on it untill you look closer or try to clean it off. if you do not find any obvious problems, turn the oven on and wait a fem minutes, then see if the bake element is glowing. Also look at the broil element, they should both be glowing at least a little orange. Compare how it works to the other oven that works properly. If only one of your elements is glowing, either you have a bad element (which is usually apparent on visual inspection) or a bad relay board that controls the element. The element is easy to change, onlt a couple screws and 2 wires (turn off the breaker first!!), the relay board is pricey, and a pain in the tookas. if you decide to guess, try the element first. Hope this is at least a little helpful.
Apr 02, 2007 | Dacor ECD227 Epicure Electric Double Oven
Krups FEM2B Toast Expert 2-Slice Toaster Logo
104 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
ArcFlash
Level 1 Expert
Oloyede Monsuru
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
