Question about Whirlpool LGR7646E Dryer
Need to get into the dryer to fix it.
Does the top or front of the dryer pop off? I can't figure out how to get in there to fix the tumbler.
  • 706 Answers
Hello barbmaresca,
Here is a link to your dryer with exploded views and parts lists for you to look at but in general, you should be able to remove the front panel by taking out the lint filter and removing the screws that hold the filter housing to the top lid, then by prying up the front of the lid from the frame. You may need to use a pry bar or large screwdriver to pop the lid up from the clips and it should remain engaged by the back hinge plates. Be sure to disconect power before performing any service.. Here is that link
Hope this helps you..
Posted on Nov 24, 2008
Hi i went into my dryer and pushed the tumbler the wrong way and heard something pop and now the tumbler doesnt rotate how do i get to the belt this dryer is very old but looks like this one .thank you oh...
You broke the belt. To replace it, pop the top ... use a screw driver. Remove the screws at the top of the front, remove the front, the drum will fall free. Take Pictures.
Feb 14, 2011 | Kenmore 65924 Electric Dryer
I have a Maytag MDE4700A electric dryer. It quit working (turning) but still heated up. I took the cabinet apart and found that the belt was broke. Need some assistance on beginner steps for replacing...
Disconnect power to the dryer then open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening. Grasp the door with both hands and lift the door in the hinge area then draw the door assembly away from the dryer to disengage the hinges from the slots in the front shroud.
Remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Disconnect the wires from the door switch, sensor bar, and the lamp holder then unsnap the lamp holder wire harness from the front shroud wire retaining clip.
Remove the four perimeter screws holding the shroud and tumbler front assembly to the cabinet. Remove the lowest outside screw at each corner then the top screw on each side.
Pull the shroud and tumbler front assembly out and away from the tumbler while slightly lifting the top cover.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then grasp the idler puller with your left hand and pull the idler upward and to the left.
Slip the belt off the motor pulley and the back of the tumbler then pull the tumbler out of the cabinet while lifting the top cover.
Place the belt onto the outside of the tumbler and position it 1 1/2 inches in front of the rear baffle mounting screws with the ribbed side facing the tumbler.
Position the tumbler into the rear felt seal and resting it onto the rear rollers then lower the front of the tumbler onto the blower housing.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then locate the belt and create a small loop with your right hand, ensuring the belt is free of twist.
Position the open end of the loop onto the motor pulley with your right hand. Grasp the idler pulley with your left hand then pull the idler upward and to the left to clear the drive belt.
Relax your left hand and allow the idler pulley to rest down onto the belt. Grasp the baffles with both hands and rotate the tumbler clockwise for the belt to align itself.
Reinstall the shroud and tumbler front assembly in reverse of the removal steps. Lift the front inner edge of the tumbler to allow the front of the tumbler to rest on the teflon bearings on the shroud and tumbler front assembly. Check the felt seal to ensure that it is outside the lip of the tumbler.
Secure the top cover with the hold down brackets then push the front panel posts against the clips in the cabinet until it engage.
Insert the door hinge tabs into the slots in the front shroud and secure the hinges with the screws removed previously to complete the procedure.
Aug 22, 2010 | Dryers
Clothes get hung between tumbler tub and front of dryer and are scorched, what parts do I need to fix this?
You probably need a new glide kit on front panel
Unplug it and pop the topa068344.jpg to get into the machine and take a look see. This is the most simple of all dryers to repair. It uses glides on front for the tub to ride on and it uses a hanger 3e1ec1c.jpgbearing in the rear for the drum to ride on. The plastic cup that the drum is cradled in wears down to metal to metal and can actually be cut in half causing the drum to drop down and lock up. This dryer is very easy to work on. MORE HERE
Jun 02, 2010 | Frigidaire FER311FS Electric Dryer
Repair loose tumbler fin
Pop the top, remove the front, the drum will come free. Take pictures of how the belt goes around the motor. Fix your "fin" and reverse.
The top is held down by spring clips.
Thanks for your interest in
Dec 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
How to replace belt on maytag dryer, please send diagram
type in your model
they will give you a pictorial of how,
but its easy, if this is your model
use a putty knife, slide between top and front
go right and left, wheen you feel it stop, that is the top detent, push it back with the putty knife, the top will pop
when both sides are done you can swing open the top
remove the two screws on the inside where the front sit on the cabinet, 5/16
flip the door out of your way to the right or left, the the side with the door wires
take off the old belt,
wrap the new belt around the tumbler, grab a loop of the belt , run it under the idler and over the motor
back out,
two things before you pull off the front, just take a look at how the tumbler sits on the slides
always unplug this thing
Oct 15, 2009 | Maytag PYE2300AY Electric Dryer
One of the 3 tumblers inside the dryer fell off.
you actually open the top first if you look between the front and the top you will see two clips. push these in with a small screwdriver to lift the top. then there is two screws holding on the front to get it off.
May 21, 2009 | Dryers
Drum not spinning
Pretty easy fix. start by popping the top
Once you get that up then remove the front. The rear hatch gives access to the idler assembly, look in there to see the status of the belt before popping the top. The bumping could have been from a bad st of glides on front or a bad bearing on back. Impossible to tell till ya give it a look see.
Jan 06, 2009 | Frigidaire FDE336RE Dryer
Loose Tumbler Fin In dryer
most maytag dryers have push type clips that hold the top to the front. look between the top and front with a light and find them about 3-4 inches from the outer edges. once you get the top up then there will be screws that hold the drum baffles to the drum. just put a new screw in them and all will be ok. no need to replace them, just use new screws.
Dec 31, 2008 | Maytag HYE3658AY Electric Dryer
Hello, This is somewhat involved and time consuming, but if you are handy, it can be done. First unplug the dryer then start with the two screws in the hinges of the door and then the door lifts out. Two screws on the opposite side holding plastic spacers. Once these four screws are out the front panel tilts right out. The front panel will come off then 4 more holding on the front tumbler support and air duct. Removed wires from light and dryness sensor and clips holding wires to panels. Pull out the tumbler and removed belt. If your dryer gets a lot of use, then you might want to keep going and replace some more wear items while you have it apart. Remove the two drum support rollers and shafts by removing a nut on the back side of each shaft. Remove snap ring off each old shaft, install new rollers and fiber washers onto new shafts, reinstall snap ring and replaced on brackets with the old nut. Remove tension spring off idler pulley bracket and one screw holding on the bracket. Install new pulley and fiber washers on new bracket and reinstall bracket and spring. Placed new belt on tumbler and reinstalled tumbler. Used drill and bit to drill out pop rivits holding on the two front glides that are attached on the front tumbler support and installed new glides and pop riveted in. Reinstall front support and air duct checking that felt tumbler seal front and rear are in place. Placed new belt on motor pulley and idler pulley. Reinstall front panel.
Dec 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Changing tumbler belt on a Kenmore gas dryer
you have to unscrew the screws in the lent trap and pull up on the top piece it has platic snaps the pop up then unscrew the front two on the front piece then the tumbler will pop out thats it.
Jan 12, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
