Question about Indesit 24 in. D61 Free-standing Dishwasher
Indesit D61D I have an Indesit D61D Dishwasher and the door on the detergent dispenser has stopped opening.Is this an easy fault to fix?
I had the same problem and a repairer said to just throw the dishwash tablet in the bottom when loaded. This has worked fine for last two years and doesn't seem to have made much difference.
Posted on Aug 29, 2007
    Sergeant:
  • 236 Answers
The solenoid has gone you will need to replace the soap unit. meaning panel off of door and removing unit.
Posted on Jun 01, 2007
Detergent dispenser doesn't open
There is a solenoid in the detergent dispenser that opens at the appropriate time to let the door open and drop detergent. The solenoid might be faulty if the door spring appears alright. One option is to stop using the powder detergent and switch to tablets. One tablet like Finish diamond in the cutlery basket does wonders.
Not sure if you can buy the dispenser to replace.
Apr 22, 2014 | Indesit Dishwashers
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Hi, I have an Electrolux E600 dishwasher and the detergent dispenser door has stopped opening. There's definitely nothing blocking it (the solution given in the manual). Any ideas appreciated. Tha
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replacedIf the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Apr 05, 2013 | Electrolux Dishwashers
Dispenser door not opening, therefor tablet not being dispensed nor is rinse aid
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 04, 2011 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwasher Detergent Dispenser not opening
An automatic dishwashermag-glass_10x10.gif detergent dispenser door can become stuck for a few different reasons. Some problems are easy to fix, while some require more work. Repairs are basically the same no matter what brand of automatic dishwasher you have, although specific parts might be required. Fortunately, even if the detergent dispenser needs to be replaced, the problem is not an emergency. The dishwasher will clean dishes fine even with a stuck detergent dispenser.
    Fixing a Stuck Automatic Dishwasher Detergent Dispenser
  1. Step 1 Move the basket that holds silverware as far from the detergent dispenser as possible, or make sure no tall items are blocking the dispenser. Also, keep other items such as plates and pans away from the dispenser. Anything that winds up touching the dispenser during the wash cycle can cause the dispenser door to stay closed. Run the dishwasher to see if this solves the problem.
  2. Step 2 Remove the front door panel according to your instruction manual, or find the manufacturer's instructions online, which will probably be in a PDF file. The panel is typically held on by 6 to 8 screws along the edge, which you can see when the door is open. With most models, you won't need to remove the screws at the bottom of the door, which are part of the hinge assembly.
  3. Step 3 Clean the detergent dispenser thoroughly from the inside of the dishwasher and the exterior side as well. Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.
  4. Step 4 Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
  5. Step 5 Purchase a new switch if re-aligning the old one does not fix the problem. Typically, these switches cost under $10. See Resources for a link to different manufacturers where you can buy the part.
  6. Step 6 Label the two wires connected to the switch so you can correctly reconnect them afterward, and then remove them from the terminals by holding the slip-on connectors --- not the wires --- and pulling firmly. Use a pair of needle-nosed pliers for a better grip. Then remove the switch from the dispenser by removing the screws holding it in place. Connect the wires to the terminals of the new switch, and attach the new switch to the detergent dispenser. Replace the door panel.
  7. Step 7 Run the dishwasher again to see if the switch replacement has done the trick. If not, decide whether to replace the entire dispenser according to the manufacturer's instructions, or call a repair technician.
Nov 14, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
The detergent dispenser sliding door will not stay closed
it is a very tiny plastic "tooth" that let open automatically the door when the washing program selected reach the opening point, the only good solution I suggest is to add the detergent after the first hot wash (just open the main door and drop it in!)...of course the best is to change this door locker with a new one...good luck!
Nov 17, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Maytag mjd 2005dishwasher
Try what my wife does. She uses the individually contained detergent/rinse bubble packs (tab packs). No messy granular detergent and easy to simply place inside the silverware basket. Your dishes should wash spotless, like ours. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Maytag 24 in. MDB9750AW Dishwasher
Permanent emptying on Indesit D61D Dishwasher
tilt it back the base is flooded have some towels to mop up the excess water then you are away again
Oct 01, 2006 | Indesit 24 in. D61 Free-standing...
Indesit 24 in. D61 Free-standing Dishwasher Logo
453 people viewed this question
Top Indesit Dishwashers Experts
Marvin
Marvin
NOEL
NOEL
Ngoro
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
