Question about InFocus X1A Multimedia Projector
My infocus x1a has a black shadow on the right side projection
We don t find the reason of that.
no pb on the light, it makes that with all sources.
can you help us?
excuse for my bad english I am french.
thanks
    Scholar:
  • 167 Answers
This is a common problem and is most always caused by a failing "light pipe/tunnel" They are not to difficult to
replace but it can be tedious. The part is around $80 US
Cheers
Posted on Dec 30, 2009
I have a vertical shadow about 1-2 ft in width running up the right side of the projected picture. The bulb was just replaced this year and the shadow didn't start until some time after the bulb was...
The light tunnel has collapsed. Google "infocus light tunnel." You can glue it, as I did, but it tends to break again. From what I have read nobody has a good fix and the manufacturer has ignored the problem which has alienated a lot of customers. They won't even sell a replacement tunnel. Good luck!
Dec 01, 2010 | InFocus X1 Multimedia Projector
InFocus X1A - while watching, the picture went out and then the unit had a flashing red light where before its always been constant green indicating the unit was on. I dont have a manual. Any ideas?
check the lamp. if it has bulges, black spot, fogging, or flaking, or dust is clogging the side vent screen, replace the lamp. if the lamop is ok, check the colorwheel. if you hear a high-pitched whir, the wheel is ok. if you hear grinding or chirping or nothing at all, replace the colorwheel. if both are ok, replace the power supply. you can get parts from an infocus service center or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 23, 2010 | InFocus X1A Multimedia Projector
The right vertical side of the projected picture seems to be slightly shadowed. Is this the lens or for some strange reason is the bulb going out? It only has about 200-300 hours of use on it
if you have the dp6150 (lcd projector), you have a lens or mirror out of alignment, or something obstructing the light from the inside. if you have a dlp projector (not the dp6150), the light tunnel has collapsed and needs to be replaced. you can get the part from an infocus service center (like av solutions in ny), or send it to them for repair. they're really good. www.avsolutionsny.com
Jan 12, 2010 | InFocus Proxima DP6150 Multimedia...
Infocus X1a LONG startup times
Sounds like the power supply is weak if it has to run for awhile before it functions. The control board could also be the issue. Does it make any grinding or buzzing noises?
Jul 18, 2009 | InFocus Televison & Video
Infocus X1a no picture, solid green LED
if the lamp is new, it could be the power supply (the ballast is built in to the ps). but make sure you have the right lamp. the X1 and X1a have an sp-lamp-019 and the similar X2 and X3 have an sp-lamp-018. the lamps are almost identical except for the wire configuration on the lamp plug. make sure the wires in the plug match the positions in the socket. also, when you turn it on, if you don't hear a high pitch squeal, the colorwheel is not working. and if that isn't working, the lamp won't either. also check to see if the lamp door is closing properly and hitting the switch at the top of the opening.
Jul 12, 2009 | InFocus X1a DLP Projector
Heyya got a infocus x1a ..im running it from vista...but there is no recognition--the projector is searching ..but what is it searching for..also there is a yellow blurring to the left of the projected...
the light tunnel is collapsing. that's causing the yellow bluring. as for the recognition, make sure that the resolution matches what the projector can handle (max 1024x768).
Apr 30, 2008 | InFocus X1 Multimedia Projector
Infocus X1A Projector
This is a very common issue with the Infocus projectors. Sounds like the mirror tunnel that sits right behind the Color Wheel and concentrates the light source onto the DLP chip. This tunnel which is shaped like a small prism is very fragile and can "fall apart" over time. Some have attempted to try and remove the tunnel and repair with limited success. Otherwise you may either need to send the unit in for repair or find a dealer who can order the part for you.
Here is another who had the same issue;
http://www.fixya.com/support/t401456-infocus_x3_video_problem
Mar 14, 2008 | InFocus X1 Multimedia Projector
Shadow on right side of screen
check the connector of DMD module. Service all projector and reinstall.
Viren
Nov 18, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus X1A Multimedia Projector Logo
137 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
