Rs232 software Dear Sir, I want to control my panasonic projector PT-LB51s Through my laptop using rs232 commands,pls describe me with details which software to be install in my laptop,wiring diagram of serial port 9pin male to rs232 port 8pin fe-male in projector.currently using windos xp. Thank you, With regards, Dinesh.
kleeper
  • 87 Answers
SOURCE: rj45 male to db9 male cable for ups
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal PC pin UPS Pin UPS signal RxD 2 2 TxD TxD 3 8 RxD GND 5 7 Ground FG Shield 4 Frame Ground Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A computer --------- Inside the Connector--------- UPS DB9-F | | RJ45 pin - signal | | Pin - Color | | 4 DSR ->|---+ | | | diode resistor | 6 DTR ->|---+---->|----///---o kill power | 8 Orange | | 1 DCD <-|----+ | | | | 2 RxD <-|----+----------------+--o low battery| 3 Brown | | | 7 RTS ->|----------+--///--+ | | | | | +--///--+ | | | | 8 RI <-|----+----------------+--o on battery | 2 Black | | | 9 CTS <-|----+ | | signal | 5 GND --|-----------------------o ground | 7 Red | | 3 TxD | | | chassis | Chassis/GND |-----------------------o ground | 4 Black | | | Not connected | 1, 5, 6, 9, 10 --------------------------------------
Posted on Oct 24, 2008
SOURCE: Need a motherboard with DB25 male RS232 serial port
to get ur motherboard just go to the website of that ,,u can find it bt surfing
Posted on Dec 06, 2008
SOURCE: xp installation in cq40 301
check the kind of Hard disk if SATA ,,change sata mode to ATA or disable sata mode on bios
Posted on May 05, 2009
SOURCE: no connect to rs232 serial, ports PC
df1c50d.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Posted on Aug 25, 2009
Testimonial: "Tanks a lot, i obtain solution"
SOURCE: how to compaq cq40-301tu install windows xp
You need to have SATA drivers, before installing Windows XP. SATA drivers are not included in the CD, unlike Vista. There are many websites which explain how to include SATA drivers in your CD. You may have to find right SATA drivers depending on your laptop.
Posted on Sep 06, 2009
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
What is pc contol
When using a special cable, pins 1, 4 and 7 of the PC control connector on the rear of the projector are used to receive RS232 serial commands from the PC to control various functions remotely in the projector.
Mar 02, 2011 | NEC VT460 Multimedia Projector
Network adapter not found when running wireless program
Sounds like the Apple Dealer is onto the right idea.Unfortunately wireless control for projectors is still in it's infantcy and subject to compatability issues. A complicated alternative is to "Try" a wirless bridge adaptor in between the laptop and the projector. using the lan port on the projector, you would set up a mini lan between the projector and the bridge, and you would get a wireless connection between the mac and the bridge.
Probably too complicated, the extra cable may just be the go for now until panasonic release the firmware upgrade for you.
Good Luck in the Courtroom!
Jan 17, 2010 | Panasonic PT-LB80NTU Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
RS 232 control
..did you ever solve this? i am trying to write some code to do the same thing with no luck at all. and the manual does not seem to help much besides letting me know that I have to use 'PON' and pad it with a start bit and an end bit. i find nothing online as well.
Dec 28, 2008 | Panasonic PT-AE2000U Projector
Panasonic LCD Projector PT-L720V
Press 'menu' and 'enter' buttons at the same time.
Mar 18, 2008 | Panasonic Videoprojector PT-LM1E...
I need a wirless driver for a mac computer
Hi again,
Seems that you posted twice. Pls, here is the link to your other post.
Cheers.
Feb 07, 2008 | Panasonic PT-LB60NTU Multimedia Projector
85 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
